Direct Port Methanol Injection Setup
Old Feb 17, 2011 | 08:20 PM
  #111
s2000Junky's Avatar
This is my idea, 5 T's... the top one is where the solenoid is run, each T down attaches to an injector at each port. No more then aprox 1" of line would be needed after each T to connect the solenoid and injectors. There would be a cap at the end of the outside T's and approx 12" of hose running the length of the manifold for the distribution T's to the injectors. This is my idea for the least amount of fluid siphon. What do you think? You mentioned 3 T's?
__I__
Old Feb 17, 2011 | 08:22 PM
  #112
s2000Junky's Avatar
Nice work saidam, looks clean!
Old Feb 17, 2011 | 08:51 PM
  #113
EternalLx's Avatar
__I__
Heres my idea
Super clean Siadam!!
Old Feb 17, 2011 | 08:54 PM
  #114
boostedf22c's Avatar
Originally Posted by siadam,Feb 18 2011, 01:17 AM
That looks really nice.
Old Feb 17, 2011 | 09:00 PM
  #115
s2000Junky's Avatar
Originally Posted by EternalLx,Feb 17 2011, 09:51 PM
Heres my idea
I see, yeah pretty much the same as what I was thinking, but your running longer lines to the 1 & 4 cylinder with two less T's. I suppose I could just run 90's instead of T's on the end (1 & 4 cylinders) Probably splitting hairs either way. Yours has less angles so its likely better. Thanks again.
Old Feb 17, 2011 | 09:12 PM
  #116
EternalLx's Avatar
Yes 1&4 is longer but if your going to make all the lines equal but then have the solenoid further back then your just increasing the delay even more.
Glad to help/bounce ideas around
Old Feb 17, 2011 | 10:31 PM
  #117
s2000Junky's Avatar
The solenoid would still be in the same place. Just a slightly different shape on the injector lines. But after looking at yours its splitting hairs.
Old Feb 18, 2011 | 05:24 AM
  #118
siadam's Avatar
Line length isn't an issue. I thought it was at first, but once I thought about it, consider this.
If you have a single T
1. Coming from the pump
2. Nozzle end/jet
3. Open
Will that line ever pressurize enough for the nozzle to start spraying?
No.
All lines have to pressurize before it will start to spray, yes the nozzle/jet could leak out, but not enough to be productive.
With that said, you could have 4 lines, and all lines will need to pressurize before it will spray. So if one is longer than a short one and vice versa, that won't be a concern as the short one won't spray until the long one is full and up to pressure.
  #119
siadam's Avatar
Thanks. Except for the stupid freaking red map sensor, lol. I'll be swapping that out @ the tune w/a 4bar black one !!
Old Feb 18, 2011 | 08:23 AM
  #120
s2000Junky's Avatar
[QUOTE=siadam,Feb 18 2011, 06:24 AM] Line length isn't an issue.
