Direct Port Methanol Injection Setup
Old Feb 16, 2011 | 05:03 PM
  #101
siadam's Avatar
Originally Posted by HiVolume,Feb 16 2011, 01:56 PM
For a direct port methanol setup, a solenoid should be used, but should one solenoid be used for every port, or can a solenoid be placed before the 4-way split?
A solenoid is best, b/c it doesn't detract from the overall performance of the kit. Meaning you don't loose pressure off the pump for the cracking pressure of the checkvalves.
However, to do it correctly with a solenoid, you need to have one AFTER the block and before EACH injector/nozzle. Otherwise, you could use a single checkvalve before the distro. block.
This is cost prohibitive for most people, I am using 1 checkvalve before the distro block. I kept the lines short, and mounted the block on my intake manifold, I am going to see if this causes me any problems. If it does, I'll adapt, but I'm curious how "bad" it will be.
Old Feb 16, 2011 | 05:05 PM
  #102
siadam's Avatar
Originally Posted by camuman,Feb 16 2011, 02:07 PM
you have an amazing amount of patience my friend. i cant wit for video of your car absolutely raping. are you going to do a tune on and off meth like in the past?
Eh, I've learned my lesson in the past. Rush something and it takes twice as long in the end.
I'm just an average guy, learning like everyone else. Trying to give back what I've learned to help the next guy coming down the same path like others have done for me.
My last tune was all methanol. It cracked when the w/g opened and hit full spray up top.
I think w/the direct setup, I will have more control and with the updated controller and be able to dial it in more exactly.
Old Feb 16, 2011 | 05:12 PM
  #103
JoeyBalls's Avatar
Originally Posted by wadzii,Feb 16 2011, 04:15 PM
meth + race gas kind of defeats the purpose
How do you figure? Meth is only a small % of the combustion mixture, take the 93 and replace it with Q16, you are going to be better off..............
I would think anyway?
Old Feb 16, 2011 | 05:39 PM
  #104
neeman77's Avatar
Well I was able to add more timing without getting knock and I was at 75% injector duty cycle at 11.5-12:1 air/fuel with my IAT's falling from 160 to ~105 if I remember correctly.
Old Feb 17, 2011 | 09:23 AM
  #105
s2000Junky's Avatar
[QUOTE=siadam,Feb 16 2011, 06:03 PM] A solenoid is best, b/c it doesn't detract from the overall performance of the kit.
Old Feb 17, 2011 | 04:56 PM
  #106
EternalLx's Avatar
You could keep the lines short by using 3 Tees instead of a 4 port block. Tho that cant really be a "clean" install
Old Feb 17, 2011 | 07:16 PM
  #107
s2000Junky's Avatar
Clean? Have you seen my engine bay? They don't call me Junky for nothin
Its something to consider, definitely cheaper. If you mount the block on the manifold vs fire wall though do you think the T's would still be an improvement? Share what your thinking?
Old Feb 17, 2011 | 07:46 PM
  #108
EternalLx's Avatar
With the right Tees and positioning I think your solenoid idea will work better. the block holds a good amount of meth for it to be siphoned in.
Old Feb 17, 2011 | 08:00 PM
  #109
s2000Junky's Avatar
I was wondering about that. Thanks for your input
Old Feb 17, 2011 | 08:17 PM
  #110
siadam's Avatar
