Disassembled Motor - Piston Carnage Pics
Old Sep 14, 2023 | 04:25 PM
  #31
umair's Avatar
Originally Posted by Dizings2k
I spent about 1.5 hours with Jeremy today as I dropped off my motor/cylinder head for rebuild. Long story short, there are clear signs on my piston beyond the broken ring that show melting from detonation, even though the plug doesnt show signs of detonation. He suspects I have a fueling issue.
So, while this motor gets rebuilt, I'm going to dive down the rabbit hole of somehow troubleshooting/testing my fuel system without a motor in the car. Also, I'm going to probably switch out my EMS to something with failsafes for fuel pressure and voltage.
I current have a 255 walbro fuel pump with the SOS larger regulator thing in place with 1050x injectors on the stock 2006 returnless fuel system. Injectors only hit 80 some percent duty at 14psi so fueling was never a concern, however that was not in a track environment so I dont know if that would have an effect on the fueling when it comes to this or not.
Also we discussed the fact that my alternator recently died on track, causing all kinds of crazy voltage errors and it was way overcharging the battery.. so my AFR sensors, fuel pump and injectors all may have not had the proper voltage going to them causing a lean condition. Of course the alternator died at the end of a 130mph straight when I was at redline/full boost... so if this did happen, it wouldve only taken a second of leaning out to cause all this.
Any recommendations on fuel system changes I should make/check out?
Is your pump rewired? I have the walbro 450 with no issues at all with a rewire. Are the injectors by ID? I have also heard that using an adapter harness on the injectors has caused people many problems.
Old Sep 14, 2023 | 05:13 PM
  #32
noodels's Avatar
Yes can spot in the pics now,
easy when one has the diagnosis ! well done that man
Old Sep 14, 2023 | 05:27 PM
  #33
Dizings2k's Avatar
Nope, stock wiring on the 255 pump. Also I AM using the PnP pigtail things with the 1050 injectors... perhaps a soldering hardwire is in my future.
Old Sep 14, 2023 | 08:17 PM
  #34
flanders's Avatar
Have you done a flow test on the injectors?
Old Sep 15, 2023 | 03:15 AM
  #35
umair's Avatar
You should definitely do a hardwire as well.
Old Sep 15, 2023 | 08:48 AM
  #36
Car Analogy's Avatar
Where did these pigtails come from? My research the ones supplied by ID are very good, ones supplied by almost anywhere else highly suspect (spotty quality control. some work, some don't, even from same source).
Hardwire if done right is more reliable, especially in a track environment.
Old Sep 18, 2023 | 10:06 PM
  #37
RolanTHUNDER's Avatar
+1 on this for sure. I can vouch for the SOS rewiring kit. Just ensure, and I mean this: ENSURE that you crimp every terminal cleanly to avoid having heat or bad ground issues. Heat will melt the plug at the fuel pump carrier
Old Sep 18, 2023 | 10:07 PM
  #38
Is it possible for the alternator to overcharge if it's failing? Either way voltage needs to be in a certain range for any and all sensors including your fuel injectors that work off battery offset to work correctly. Why don't you upgrade to a return style system? Even if you don't need it now you might in the future
Old Sep 19, 2023 | 01:46 AM
  #39
Rather don't run the supplied flimsy injector pnp harnesses. Rather run solid state adapters (no loose wires) that create a more stable connection between the OEM injector harness and your ID's connectors.
Old Sep 19, 2023 | 10:47 AM
  #40
Spoolin's Avatar
Glad Jeremy was able to pinpoint what the root cause seems to have been with the engine failures.
As far as fuel system changes, I'd definitely hardwire your injectors in and ditch the PNP clips. Changing to a return style fuel system may be a better option as well. The return less fuel systems seem to be too finicky and limited to their capabilities.
