Does Anyone use an Oil Pressure Regulator to the Turbo?
Tripped across this on a Supra site, designed for ball-bearing turbos:
It provides the turbo with a steady oil pressure rather than just using a restrictor. Here it is mounted on a special return line fitting from Driftmotion. The regulator set at 40psi is from Turbosmart and has a bracket for a variety of mounting locations: against chassis, onto oil filler cap, onto breather return line, onto breather tank.
It isn't free (regulator is $120, Driftmotion's kit about $250) but not that expensive considering the overall cost of a turbo installation, ECU, and tuning. It was introduced at SEMA in 2016.
It helps prevent compressor or turbine stage oil leaking or smoking, and takes the guesswork out of oil restrictor sizing for more efficient and effective oil delivery. Providing an aftermarket turbocharger with the ideal oil pressure has always been a challenge. Traditionally, the turbocharger’s oil feed has relied on a restrictor system, which are difficult to set up correctly. When incorrectly sized or set up, they can be the cause of turbo seal leakage and blow-by. Turbosmart’s Turbo Oil Regulator ensures the oil pressure going to the turbocharger never exceeds the maximum pressure turbocharger manufacturers specify for oil supply, regardless of engine oil pressure. The result is an oil delivery system that is more reliable and easier to setup than a standard restrictor system.
Garrett says:
Restrictor size will always depend on how much oil pressure your engine is generating-there is no single restrictor size suited for all engines. Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo. The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
