Dumb Turbo question. Will Check Engine light.....
Old Apr 4, 2006 | 07:28 AM
Badmix's Avatar
Default Dumb Turbo question. Will Check Engine light.....
...come on when I install turbo kit. I dunno why Im asking this, jus something Id like to find out about. I did some motor work and nitrous on my Dodge Neon R/T and on occasion Id trip the check engine light. The code was Down side O2 sensor, I replaced it and would get the code on occasion. I jus reset the ECU ea. time.
I was jus wondering.
Thanks
Old Apr 4, 2006 | 08:05 AM
SIIK2NR's Avatar
To answer your question... a properly installed turbo kit will not induce a CEL.
The peripheral parts such as straight pipes will but can be adjusted with a fowler.
If the turbo kit itself sets off a CEL...it's due to some serious problems.
The kit itself if properly tuned with engine management and correct A/F ratios...will not set off any CEL's.
Old Apr 4, 2006 | 11:21 AM
HybridHatch88's Avatar
[QUOTE=SIIK2NR,Apr 4 2006, 08:05 AM] To answer your question... a properly installed turbo kit will not induce a CEL.
Motoss
Jan 6, 2010 07:30 PM
xxlap1xx
Aug 6, 2007 07:53 AM
froz1
Jan 4, 2006 05:46 PM
25psi
Jan 24, 2005 08:59 AM
spoolinmp3
Dec 19, 2002 04:43 AM
