Dynoed my CTSC'ed 01 S2000
Old Jul 29, 2008 | 07:50 PM
  #121
RAIN H8R's Avatar
i understand completly. I installed it the correct way. Im calling King tomorrow to try and get in for saturday oir next week sometime after work. Ill try to work some magic and have them adjust the FMU on the dyno too.
Old Jul 30, 2008 | 10:03 AM
  #122
jmoore2k's Avatar
USDM EG One item not mentioned in the Comptech Supercharger and Aftercooler install instructions (that I received) was the correct FI spark plug gap to use. After some research I found that the correct spark plugs to use for supercharged Honda S2000 (AP1) engines (with OEM Coils) should be one range colder (for street use) than stock and have gaps of .032 to .034 inch (less gap than the stock plugs). I am using the DENSO Ultra-Fine 0.4mm Iridium spark plugs gapped at .033 inch and have had no plug problems. The new plugs should be torqued to the Honda S2000 specs as too little torque will allow the plugs to work loose.
jmoore2k
Old Jul 30, 2008 | 06:38 PM
  #123
RAIN H8R's Avatar
jmoore2k, you are a walking Honda manual to me! Do you have nything else youd liek to preach?! haha Im already running NGK BKR6E plugs gapped at the OEM spec. Im going to change those out at my next oil change.
Old Aug 3, 2008 | 09:45 AM
  #124
RAIN H8R's Avatar
Well, im trying to get into King to schedule a dyno time, but they are super busy. However I was able to get to the local 1/4 mile strip. Im about a half second faster. I recorded:
2.0 60's on average, and nothing quicker
13.445 was my fastest time
103ish miles per hour
Not bad, it was very humid when i got there and i couldnt even get over 100mph as a trap. But once the sun went down i was able to get above it.
Old Aug 3, 2008 | 10:00 AM
  #125
Ness2000's Avatar
Trust me, I understand. Today is day 1 of figuring out why even heatsoaked I only made 270/175 on a 9psi pulley, 650cc Siemons, and UR FMIC.
My tuner was confident in his tuning, and I'm still waiting on my tbolt clamps.
Old Aug 3, 2008 | 01:55 PM
  #126
RAIN H8R's Avatar
WHat psi are you getting on the manifold?
Old Aug 5, 2008 | 02:19 PM
  #127
jmoore2k's Avatar
USDM EG, Have you been able to schedule a dyno test yet? With the tighter sc belt tension, I am expecting you to get higher rwhp!
jmoore2k
NW Arkansas
Black Stealth S2000
Old Aug 7, 2008 | 02:55 AM
  #128
RAIN H8R's Avatar
not yet. King is packed full.
Old Aug 9, 2008 | 06:54 AM
  #129
jmoore2k's Avatar
USDM EG, I look forward to seeing your new dyno numbers.
I have found that it is necessary to check the supercharger belt tension several times between oil changes as a new belt will stretch with miles & high rpm use. A Comptech rep told me the quick way to check sc belt tension is to rotate the belt (with thumb and finger about midpoint between two pulleys). Proper sc belt tension will only allow rotation of about 90 degrees. Without strong-arming, belt rotation of less than 90 degrees means the belt is too tight and should be loosened some.
jmoore2k
NW Arkansas
Old Aug 21, 2008 | 03:20 PM
  #130
jmoore2k's Avatar
USDM EG, No new dyno numbers yet?
jmoore2k
NW Arkansas
