E85 Question
Old Dec 20, 2011 | 09:24 AM
rikhemi's Avatar
Thanks for the info. So getting a boost controller and raising it to 14psi will be ok without the potential tune?
Old Dec 20, 2011 | 09:35 AM
InductionPerformance's Avatar
You would have to ask your tuner that. If you're talking about going from gasoline to E85 without a tune. You will not be able to do that.
Old Dec 20, 2011 | 09:47 AM
rikhemi's Avatar
Oh no. It would be keeping my current setup on 93 pump and raising it from 11-12 ish to 14.
Induction Performance, Which manual boost controllers do you sell?
Old Dec 20, 2011 | 10:11 AM
I try not to. On 80% of the cars I tune and work on I install boost solenoids that work with the ecu. If I have to then Grimmspeed or Perrin.
Old Dec 20, 2011 | 10:31 AM
rikhemi's Avatar
Can you send me your # or the cost of those solenoids to look into purchasing one. Since you tune, if I were to raise the boost, is the a/f the main thing to check in ensuring it stays around 11.1-11.8 or do I need to look at the timing as well?
Thanks for your help.
Old Dec 23, 2011 | 05:50 AM
Correct. Air:fuel is only half of it. The ignition timing needs to be in the ball park as well. If it was tuned properly it will be.
Old Dec 23, 2011 | 06:11 AM
Corey Maurer's Avatar
If you wanna go e85 I'll sell id1000s and aem FPR for $500 shipped and paypalled
Old Dec 23, 2011 | 06:28 AM
rikhemi's Avatar
On a side note, my darn wastegate bolt broke off again. So it sounded like i had a big exhaust leak since the wastegate was loose and my a/f on idle went to 16-17. When driving it went back down. So now have to drill out the broken bolt this weekend.
If i go E85, I will let you know corey. Might just stick with the boost solenoid for now to achieve around 380-400hp.
Thanks for all your help Induction Performance and any others which have posted.
Old Dec 23, 2011 | 11:55 AM
RedLineS2k10's Avatar
Manual boost controllers are unstable. You can get a Mac solenoid for $40 on eBay. Wires directly to ems.
From my last setup to now, I added 117whp on e85 and adding 3 psi. E85 is free horsepower.
Sent from my DROIDX using Tapatalk
Jaspah
Feb 4, 2017 12:12 PM
Chance S2K
May 14, 2015 07:16 AM
herecomesboost
Aug 8, 2012 02:53 PM
riceball777
Sep 21, 2011 10:00 AM
myflys2k
Sep 16, 2009 06:28 AM
