emanage issue
Old May 21, 2009 | 03:05 PM
chillout18's Avatar
Default emanage issue
Dont have my s/c belt on but wanted to hook up my emanage to update it and make sure car runs right. Emanage does see I have an F20. Settings are set to 4-8-C. Vtec settings are zeroed out. I set map clamp to 2.90.
anything else I should check. no check engine light btw, car idles fine except when I give it gas it starts to sputter.
thanks
Mike
Old May 21, 2009 | 04:23 PM
ChefJ's Avatar
Whats in the fuel map, ignition map. Or are you bypassing everything.
Old May 21, 2009 | 04:25 PM
chillout18's Avatar
everything is zeroed out...running stock injectors too
Old May 21, 2009 | 04:31 PM
chillout18's Avatar
on the board itself, the rotary switches i set the vtec to zero also
Old May 22, 2009 | 04:33 AM
Kirpich's Avatar
I had that too, but I think it was at 3100. Like a redline. I ended up installing a Missing Link on my MAP. It solved it, boost clamp didn't seem to work.
You're running V1.11, right? The only version that seems to recognize F20? Same here. Well, that's what cured it for me.
Old May 22, 2009 | 06:03 AM
chillout18's Avatar
can you explain a little bit more Im not exactly too sure what I need to do. An yes Im using the older version of emanage.
thanks a lot
Old May 22, 2009 | 12:16 PM
ChefJ's Avatar
firmware
Old May 23, 2009 | 07:11 AM
chillout18's Avatar
firmware was updated
Old May 23, 2009 | 11:52 AM
chillout18's Avatar
figured it out changed one of the jumpers and emanage was looking for a greddy pressure sensor still....thanks everyone for your help
Bryan858
Apr 29, 2020 01:34 PM
Zuikan
Jun 4, 2017 08:19 PM
folex187
Aug 21, 2005 04:16 PM
skibum
Jul 26, 2005 02:33 PM
Reignman
Jul 31, 2003 11:52 PM
