EVC on turbo exhaust
Old Apr 16, 2007 | 08:43 AM
Soul Coughing's Avatar
Default EVC on turbo exhaust
Hey Guys,
So i finally got my 2.2l motor swap done on my car. The motor had a 3mm headgasket and a turbo kit installed.
The tune was done with stock exhaust... it is a big change from my supercharged T1R 63mm aural terror i had before
It made 384 at 14.5psi and when the tuner upped the boost to 16 it made no more power... so i am looking to keep the nice quiet cruising exhaust while still making a bit more power when i go hi boost...
So i was looking to do the best of both worlds and do an electroncic valve control and have it welded onto my downpipe... so when i want to race and up the boost i could open this up and be able to up the boost... has anyone done this before...? im guessing i would need to fabricate a new downpipe with valve...
any input would be appreciated...
Old Apr 16, 2007 | 09:07 AM
AP1_S2k's Avatar
My friend has it done on his SRT-4, It works nice and the car is loud as hell with it open
Old Apr 16, 2007 | 09:14 AM
do you know where i could find some of these valves?
Old Apr 16, 2007 | 09:20 AM
passmans2kny's Avatar
i just did a search in google for exhaust bypass valve a a lotta stuff came up
Old Apr 16, 2007 | 09:22 AM
AP1_S2k's Avatar
Quicktime performance is what my buddy is using on his Srt, they are a bit pricey but they are nice and you can open and close it at anytime, here's a link
QTP exhaust valve
Old Apr 16, 2007 | 10:03 AM
i have a look, thanks!
Old Apr 16, 2007 | 11:59 AM
AP1_S2k's Avatar
no problem and good luck
Old Apr 16, 2007 | 12:30 PM
RacerXI's Avatar
They are also known as exhaust cutouts or electric cutouts. Here is an example of one that is controlled via boost.
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=BCS
Old Apr 17, 2007 | 06:54 AM
m R g S r's Avatar
they suck and fall apart.....trust me i had one on my teg don't buy it.....it will eventually break and either be stuck open or closed....then I just ripped off my entire exhaust and ran open downpipe for about a year
Old Apr 17, 2007 | 08:28 AM
that boost bypass one looks pretty nice, yea im debating just running open dp for a while when i first install the kit
-DOZER-
Nov 29, 2007 05:55 AM
Tolgahan Ures
Oct 29, 2007 01:18 PM
abv
Sep 9, 2007 07:37 PM
