FMIC installed!.......on a Supercharger :)
General: I'm supercharged w/o the aftercooler and at 7 lbs with no engine management. I dyno'ed at about 280whp on my stock exhaust with cat, brand new clutch, and with heavy 18 in. wheels.
Great job guys! Can't wait to see your final numbers and impressions!
Pushin9: How much welding was needed or did you just use silicone connectors?
Oh, good...a perfect chance to rant.
But before the rant part...VERY NICE WORK, Kratos...Kudos for having the balls to do something different and for tackling the project yourself. I admire anybody who welds so that probably means more coming from some of the other guys who have posted. Nice choice of IC, too...cast end tanks, ftw.
And most guys who use the "r" word when talking about bov's secretly like the sound of a nice blow-off valve. Just don't confuse a bov's sound qualities with its effectiveness. Stock 1G dsm bovs are among the best out there up to 15-20 lbs but they don't make very much noise.
Also if you end up short a t-clamp or two don't worry. You can always just double clamp with crappy worm clamps. I have a connection on my galant set up with doubled-up el-cheapo' clamps and have zero leakage at 20psi. And I don't think that pipe-end even has a bead.
Slimjim, about your comment on boost drop: you are thinking like a turbo guy which, I see by your sig, you are.
When you introduce a restriction to the intake system (like an intercooler) you WILL reduce boost at the throttle body...UNLESS you increase the boost ahead of the restriction. Your boost control system (mbc and/or boost gauge and/or ebc, and your waste gate compensate for the loss but your turbo is working a little harder to make up the difference. One of the big advantages of a turbo vs. a supercharger is the turbo has "boost to burn" up to the limits of the torbo's design.
Since superchargers boost levels are completely dependent on engine rpm they don't have the luxury of just turning up the boost to compensate for new restrictions.
In my experience a quality FMIC of reasonable flow efficiency won't result in more than a pound or two pressure loss. But my experience is with turbos putting out between 12 and 25 lbs boost where a couple of lbs isn't a big deal and where you can turn the boost up a little to compensate (at the cost of reduced thermal efficiency).
Not surprised the S2K "aftercoolers" (more on that in a sec) get heat-soaked. BTW, you may find your air/air setup does too in heavy traffic. Mine (in a turbo galant) does. Of course it's a little hotter down here on the Gulf Coast than up there in the Great White North.
Now the rant...
WHY do these supercharger companies insist on calling an air to liquid intercooler an "aftercooler"? Maybe this has been discussed before and its a minor point but it has always bugged me. An "aftercooler"? Like there might be such a thing as a "precooler" or (worse) a "beforecooler"? Like you would cool the intake air to ambient BEFORE you compress it? Like it isn't ALREADY ambient? /RANT
BTW... in my turbo world, an air to liquid intercooler is a hot setup. (as in good, not as in thermally sucky) Simplifies packaging and permits a really short rout from torbo to throttlebody.
oh...and I don't think bigger pipes cause pressure drop...they only improve flow. And longer pipe routs don't cause significant pressure drop either. Additional lag, maybe.
When you introduce a restriction to the intake system (like an intercooler) you WILL reduce boost at the throttle body...UNLESS you increase the boost ahead of the restriction. Your boost control system (mbc and/or boost gauge and/or ebc, and your waste gate compensate for the loss but your turbo is working a little harder to make up the difference. One of the big advantages of a turbo vs. a supercharger is the turbo has "boost to burn" up to the limits of the torbo's design. Since superchargers boost levels are completely dependent on engine rpm they don't have the luxury of just turning up the boost to compensate for new restrictions.
Now the rant...
Just got off the phone with my tuner! I will be on the dyno Friday at 5:00pm!! So I will be able to give you all my before and after numbers and whatnot.
I guess the first problem is that I know nothing about BOV's ... I will give you a better review at the end of the week after my tuner is done. and Yes I was at 9psi.
[QUOTE=mrsteve,May 21 2007, 09:59 AM]But it seems like your priority here is getting the loudest noise from your BOV and not increasing power output.
Originally Posted by General Kratos,May 21 2007, 09:39 AM
I'm glad I didnt stick with it then. Let me guess, its not blowing out loud enough in high RPM's and you can barely even hear it in low RPMs? Your running 9lbs right?
Originally Posted by pushin9,May 21 2007, 08:27 AM
I wish I would never of had the BOV flange welded on there now. Yeah I like the BOV "pssss" sound but that has nothing to do with the reason for a FMIC ... could have added/changed to BOV on my old setup.Here's what it does...Let's say you are accelerating...hard (imagine that!) and you let off the gas to shift. When the throttle plate closes the stream of high pressure pulses from the thrbocharged intake air hits the throttle plate and backs up...eventually these pressure pulses bang into the impeller inside the turbo. This is hard on the turbo's internals. The blow-off valve can tell when you let off the gas and it simply vents the excess pressure off into the atmosphere.
That's a really simplified explanation. Here are some better ones, if you are interested:
Blow off valve: What it does and how it works
This one is from Answers-dot-com
I don't know how important such a device is in the supercharger world, since centrifugal superchargers have much different impeller designs from turbochargers. Also you are talking about fairly low boost levels on an S2K.
tof, you are talking about BOV on a turbo though. For our Centri superchargers, its all for show and sound. We all know that.
You sure bout that? I thought bigger pipes and longer routes would mean thats extra space of air to fill?
Last supercharger I had was a JR roots type and those don't have a surge issue since the bypass reroutes excess air back through the system when you close the throttle and there is vacuum in the intake.
As to the pipe stuff...yes, bigger pipes hold more air. So pressurizing them takes longer. But they still end up with the desired boost pressure. Again we are talking about lag, not pressure drop.
Forgive my mix of knowing some stuff but being really ignorant of others. I have lots of turbo experience but have never been involved with centri. type superchargers. I'm here to learn.
Originally Posted by General Kratos,May 21 2007, 12:06 PM
You didnt throw a CEL by not having both of these tubes connected to your IC pipes? (bypass and factory air pump)
AEM EMS
Originally Posted by tof,May 21 2007, 12:16 PM
Ahh...so you are saying compressor surge is not an issue with a centrifugal supercharger?
