Fuel injector choice
Old Jun 26, 2017 | 08:03 AM
  #121
hatrickstu's Avatar
Originally Posted by c_me_go
pickel?.. how do you do that? and how long does it need to sit to do that?
There is a warning card in the box you got them in with some information. Also, a good read here:
Everything You Never Wanted to Know About Alcohol - Injector Dynamics
If its going to sit after being run in alcohol for more than a couple weeks, pull the injectors, spray some WD40 down them, and actuate the injector. You can actuate it by tapping some wire leads from the injector to a 9v or 12v battery. This will get the WD40 down through them.
Old Jun 26, 2017 | 08:06 AM
  #122
c_me_go's Avatar
ok.. this is only if I run alcohol? what about if i am running E85 and 93, flex fuel
Old Jun 26, 2017 | 09:55 AM
  #123
hatrickstu's Avatar
If you shut the car off after it has been running 93 you are fine. Its only if you have are going to let it sit after running alcohol through it (E85, E98, etc).
Old Jul 3, 2017 | 09:00 PM
  #124
MARK AUS S2K's Avatar
Originally Posted by hatrickstu
We have a really badass fuel flow calculator on our website you can play with to help here.
Fuel Flow Calculator - Injector Dynamics
You will 100% be smart in stepping up to the ID1700's. Rough guesstimates show a fuel pump supply issue as well though. Looking at needing roughly 346l/h at 9,000rpm. The single 450 at 72.5psi (43.5psi base and 29psi boost) only flows 286l/h.
How on earth is any average person supposed to enter all of the details into this injector calculator. I mean seriously?!?
All I want to know is if I upgrade my ID1300 to 1700X will me Walbro 450 fuel pump max out before I see any benefits?
Old Jul 4, 2017 | 11:03 AM
  #125
Mijae007's Avatar
LOL i thought the exact same thing haha
Old Jul 5, 2017 | 06:11 AM
  #126
hatrickstu's Avatar
That calculator is pretty straight forward. The only thing that isn't 100% clear is the cam aggressiveness rating portion, which is really just an overall engine efficiency rating. I typically do 8 or so on Honda engines. If you know what four injectors flow at "x" pressure and know what the pump flows at full system pressure it's pretty easy to figure out which is your limiting factor. Our information is right on our page, and the Walbro flow can be found here:
Walbro Fuel Pump F90000267 E85 High Performance 450LPH
Old Jul 6, 2017 | 12:47 AM
  #127
Engine Displacement (Liter) = 2
Number of Cylinders = 4
Valves per cylinder = 2? (is that right?)
Lambda at WOT = = ??
Lambda at Idle = ??
Fuel Pressure (psi) = ??
Cam Aggressiveness = 8
Can anyone help with this please?
Old Jul 6, 2017 | 03:54 AM
  #128
flanders's Avatar
No we have 4 valves per cylinder
If you hover over the question marks there is a nice hint on the values, lambda at WOT 0.81 and 1.0 at idle seems good.
Fuel pressure I don't know what you use, stock AP1 is around 50 psi
Old Jul 6, 2017 | 05:25 AM
  #129
hatrickstu's Avatar
Lambda at Idle = ??
Like the guys said below you, you have a four valve.
Lamda at WOT I would put in .78. I always goes a tad richer because I would prefer we overshot our fueling needs a bit. Lamda at idle is 1. I don't know what your base pressure is, I would start at 43.5. If you have enough injector at 43.5, you will have enough if you increase fuel pressure. Again, I always try to give some overhead. I would try and keep IDC under 90%.
Old Jul 6, 2017 | 05:56 PM
  #130
What a FANTASTIC calculator!
Brilliant!
