Fuel pump wiring and amperage questions
i have the 450 and supposedly its good for 700 I'm shooting for 600 and thats not gonna be an issue for me at all with the 450 i also have the sos wiring kit and pump kit as well because the 450 doesn't fit well in the hanger unless you make your own rig
Originally Posted by rmerchant3' timestamp='1456963902' post='23897421
I agree with all above, and will add that you need an adjustable FPR as well. I had an AEM 320lph pump with the SOS wiring kit and it overpowered the stock FPR and bent the diaphragm. I couldn't get the pressure I needed under boost, as it essentially made it a static FPR instead of a rising rate. It cost me a money in dyno time, as I had to schedule another appointment.
If the OP needs more then stock pressure to hit his fuel demands regardless of injectors or fuel pump size, then yes upping the pressure at the rail is a way to help. But its by no means the rule in this situation. Ive never heard of "bending" the diaphragm in the stock fpr by simply upgrading the fuel pump capacity to the number of standard up sizes we have to select from. It should be able to handle it. I never had a problem myself running a FB340 with stock fpr when I was boosted with ID1000.
I am not the first person that this has happened too. There are other instances in the SOS FAQ thread. I did exactly the opposite. I ran into TOO MUCH fuel. The extra amperage provided with smaller gauge wires on a healthy A/M pump puts out a lot of flow and pressure as compared to a factory wired A/M pump. I wasn't increasing my pressure either. MY tune is set off of a non vacuum assisted pressure of 45psi. So that gives me a range of 35-56 for my setup.
herecomesboost
Aug 8, 2012 02:53 PM
riceball777
Sep 21, 2011 10:00 AM
