Greddy Turbo Install
Old Apr 11, 2008 | 08:01 AM
  #571
KnowledgeIsPower's Avatar
what spark plugs are to be used with this kit? part number?
anyone have a write up on how to install tru boost gauge?
Old Apr 11, 2008 | 08:18 AM
  #572
JoeyBalls's Avatar
Greddy Racing ISO 8 Spark Plug
Old Apr 11, 2008 | 09:13 AM
  #573
TRBOKEV's Avatar
NGK 4554 for me.
Old Apr 18, 2008 | 11:01 PM
  #574
kix's Avatar
kix
Got the oil pressure sensor in and wired up this week. If any of you install an oil pressure sensor, be sure to note that you will need this:
You will need it because the greddy oil relocation adapter blocks only accept 1/8" BSP. That stands for British Standard Pipe
I actually spent quite awhile at the local home depots, lowes, pep boys, etc trying to find a 1/8" NPT female to 1/8" BSP male converter. I've read in other threads that it is OK to force fit the 1/8" oil pressure sensor into the 1/8" BSP plug in the Greddy oil block. However, in my case, I could only get 3 threads on before it started binding. The fear of fudging the threads or blowing out the oil pressure sensor was enough for me to want to do it the right way... you can find the adapter here Adapter
Oil pressure sensor... good to 120psi
Picture of adapter installed
Heaps of teflon tape on the oil pressure sensor
Pressure sensor installed into adapter
Picture of gauge, wideband, and oil pressure controllers. All fitted together.
I didn't take pictures of the wiring because its just too damn easy. All you need to do is run 2 wires from the controller to the sensor... thats it!
I got to use the pressure sensor this past few days and its great. At idle the pressure reads at 20-35... normal cruise is around 70-85psi...and vtec is... I dunno ... I cant take my eyes away from the road when going full wot in vtec.
Overall I'm very pleased with PLX. Their wideband and oil pressure gauges really give me a piece of mind. Now I dont have to worry about not knowing how my A/F mixture or if I have a oil leak.
Old Apr 18, 2008 | 11:25 PM
  #575
Mr.Aqua's Avatar
Glad you like it. Your oil pressure readings are exactly like mine.
Old Apr 19, 2008 | 07:42 AM
  #576
hm my aem oil pressure was reading around 60psi at idle last night...that was after cold start and didnt drive around to see if it would go down...guess i need to watch that today when im on the road
nice write up once agian
Old May 1, 2008 | 05:49 PM
  #577
kix's Avatar
kix
More toys:
I wont be doing the install for the clutch... just not enough time to pull of this job with my schedule. Its going to the shop on May 7. Can't wait!!!
Old May 1, 2008 | 06:28 PM
  #578
TRBOKEV's Avatar
Nice KIX. Let us know how it feels and if you get clutch buzz.
Old May 1, 2008 | 11:22 PM
  #579
Series10's Avatar
Awesome! Can't wait to find out about how this clutch works out for you.
Old May 2, 2008 | 07:50 AM
  #580
S2005x's Avatar
Same here. I wanna hear the results.
ALSO, are you planning on building the rear diff? ive read that it needs work once FI'd
