Greddy Turbo + Meth
Originally Posted by jwa4378,Sep 10 2008, 10:17 AM
What duty cycle are you injectors running? I would think 12.5psi would be right around their max. I believe Mase maxed out the 750's around 15 psi on Phil's car... 1000 cc were close to maxed @ 22 psi too I believe.
What is your AFR? Might try pushing VTEC back to 7k-ish. I believe that is how NFRS2000NYC had his tuned. definitely don't want to lower it from the stock 6200rpm.
I was also looking for InlinePro like numbers (assuming not fuel limited), as the meth injection takes away the problems associated with over spinning the turbine.
John
John
Meth does (Octane) allow you to run more PSI and timing, and the cooling part (water) drops the IAT's from the turbo. These both allow you to make more power out of the system, but i wouldn't expect the results to be MIND blowing, especially if the tuner doesn't want to add crazy amounts of timing and the turbo is already basically maxed out on pump gas!
Originally Posted by jwa4378,Sep 10 2008, 07:37 AM
Yeah, my kit is HP Performance. I was just saying that the larger turbine and the tubular manifold I didn't think would gave it a 10 percent power advantage at almost half the boost.
I just recently bought a Full-Race manifold. My old high boost was 415whp@18Psi (ultimate Racing log manifold). I now make 425whp@11 Psi with my full-race manifold, so all PSI is telling you is that i had alot more back pressure with my old setup but was making basically the same power.
Originally Posted by brilliant,Sep 10 2008, 08:48 AM
so..i just need a more efficient turbo like revenge's conversion if I want to make more power?
Would going from our 2.5" DP to a 3" help at all?
IMO its a POS. (Thats why im replacing mine)
I'll get it done really soon and then have Jon tune my ride so we can see what difference it makes.
Sorry just been busy with the new house. Just bought 5K worth of appliances last night and I still need to buy the dishwasher, pay for tile and have the wood floors refinished.
Glad I modded my S before I did all of this house stuff.
The pressure ratio between the intake and exhaust is very important to the output of a turbo car. The problem with the greddy kit and "the dip" is that the exhaust pressure momentarily exceeds the intake pressure. A properly designed system aims to achieve the opposite. It's not a deal breaker, but more of a hurdle.
and just to clarify, so you're saying a bigger dp will help? lol sorry i'm noob.
Header, down pipe, exhaust, and hfc. Most of it isn't worth the small gain, as the turbo is still just an 18g. The problem with better exhaust flow on this kit is boost creep, due to the small internal wastegate. NFR had his creep tuned out by pulling timing. Everything is still kind of up in the air as to how to prevent creep. I'm porting my wastegate, installing a berk hfc, and running a ti-c. Hopefully it will turn out right. I have to get off of hurricane duty first though!
I'd also like to see your first pull, and last pull. Some tunes remove the dip by lowering the tq curve right there. Not accusing, I'm just curious how your tuner did it.
I ordered the AEM Meth kit and the BERK HFC, I will keep it at 10PSI I want the Meth as more of a safety device then to extract more power, as far as the HFC I think it will allow just enough flow without causing creep, and if it does creep hopefully it will be tunable with the meth
I'd also like to see your first pull, and last pull. Some tunes remove the dip by lowering the tq curve right there. Not accusing, I'm just curious how your tuner did it.NGK 7173's FTW.
