Greddy Turbo + Meth
Soul coughing - I am a bit of a turbo noob. I was under the impression that the amoun of air flowing through the engne = air mass moved through a given volume (the engine displacement). Air mass is a function of pressure (higher pressure = more dense charge. Charge volume is the same (same IC pipe volume), so only pressure can change).
I assumed the loss in power associated with log manifolds was heat related (caused by larger amounts of back pressure). Back pressure = more heat.
I know the turbine will not flow as much as a larger turbine at the higher RPM's (turbine RPM, not car).
John
John
Originally Posted by SgtB,Sep 10 2008, 10:56 AM
7173's are not resistor plugs. I had very bad electrical problems w/them. Search the forums and you'll see much of the same.
you had problems but tons of ppl are running 7173's with FI and having no issues.
I am having no issues as well.
Originally Posted by brilliant,Sep 10 2008, 12:23 PM
yeah i know,
Originally Posted by jwa4378,Sep 10 2008, 10:17 AM
What duty cycle are you injectors running? I would think 12.5psi would be right around their max. I believe Mase maxed out the 750's around 15 psi on Phil's car... 1000 cc were close to maxed @ 22 psi too I believe.
What is your AFR? Might try pushing VTEC back to 7k-ish. I believe that is how NFRS2000NYC had his tuned. definitely don't want to lower it from the stock 6200rpm.
I was also looking for InlinePro like numbers (assuming not fuel limited), as the meth injection takes away the problems associated with over spinning the turbine.
John
John
Originally Posted by JoeyBalls,Sep 10 2008, 01:16 PM
My carf ran like complete dog poop with these plugs, stalled in traffic backfired/misfired at WOT.............I put my Greddy ones back in
Mine are gapped at .030
Originally Posted by mpower22,Sep 10 2008, 01:18 PM
Meth is a substitute for fuel. When running meth/alchy you can scale back your injectors as you are injecting a fuel substiture into the motor. When I had alchy injection in my sti I was able to scale back my injectors 20% on my alchy map. If I wasn't flooring it all the time I probably would have gotten great miliage.
John
John
I personally run the NGK iridium BKR8EIX. They are one step colder, come pre gapped at .030, is a resistor plug and only cost 7-8 dollars each. Plus they last much longer than coppers.
