Greddy Turbo Questions thread....
Hey guys I think I might have a problem
Greddy Kit with oil relocation and also using a greddy sandwich adapter (I know I'm stupid didn't see the extra oil temp until the adapter was on.
Cold oil temp (startup) is 85 PSI with a 75 degree ambient temp
the pressure seems fine on the highway everything normal except for my indle pressure
my idle is 900-1000 rpms and when the oil is 190 degrees my oil pressure at idle is 14-18 psi. This seems low. The oil is full etc. I need to talk to the shop that did the install and make sure they used 10w-30 and not 5w-30. Assuming they did what gives?
I'm using a SPA digital gauge with oil temp/pressure.
Any ideas?
Any ideas?
Normal should be around 20-25. Since the greddy kit adds a turbo, AND a relocation kit, all that distance will drop the pressure slightly. Nothing to worry about if you are running at 18-20.
Quick question guys. Doing my install of the eManage Ultimate right now and I have no clue what the small connector with the 2 wires (one white w/ red stripe, the other green or black with a red stripe) goes to. Is it necessary? Thanks in advance.
Originally Posted by TRBOKEV,Apr 17 2008, 02:13 PM
iNVIDIA v3 will be really loud.
