Greddy Turbo Questions thread....
Originally Posted by brilliant,Apr 23 2008, 11:22 AM
wow nice man #'s man! wait so that is 317 on a mustang dyno?
what exhaust do you have?
What exhaust and cat/high flow car or test pipe and size please.
hey there guys, I have a couple of questions as well...
I have an EMS with the modifry patch for the stock ECT gauge.
First question;
1. Should my normal temp bars be at half way instead of the normal one bar less than half way?
2. Are my fans supposed to stay on all the time?
I'm considering having my setting on the modifry show the stock settings, which is one bar less than half, under normal driving conditions. Am I just being too anal, or would this be something that most of you guys would do too?
I'm also going to set the fans to turn on at a certain temp via the EMS. Which temp setting should I have the fans come on at? Come someone please let me know?
Thanks FI-Team.
First question;
Thanks FI-Team.
You dictate what the bars stand for by setting the config file. Put it wherever you want it. I'm not 100% on the optimum running temp, but you should be able to find it. The turbo will add more heat, so the fans will run more.
Mustang Dyno posted 311.something hp on the print out (best run)
He took the numbers and did some math and came up with 317...
All I have is the Greddy kit (with K&N filter, probably didn't make a difference). 63mm Invidia Test pipe, and thats it...
Very good tune and numbers if so.
I want to see the dyno chart.
