Greddy Upgrade (theoretically speaking)
Old Jul 21, 2008 | 02:52 PM
  #31
Chris_Lum's Avatar
Originally Posted by Revenge,Jul 21 2008, 03:44 PM
Joey balls mentioned something about a cut off at 13psi, can anyone provide more info on the subject, would this be a problem if you wanted to increase the boost with a 2-3mm HG. If so could this be changed. Thanks
not sure if this is what he was talking about, but yes there is a boost cut in the basemap for the AP2s. But this can be changed no problem. It was just a safety set in there by the greddy techs.
Old Jul 21, 2008 | 02:53 PM
  #32
JoeyBalls's Avatar
Thumbs down
Hang on, there was a few people that tried this, this particular Turbo is no good past 10PSI I believe................
Old Jul 21, 2008 | 05:06 PM
  #33
Spec_Ops2087's Avatar
There has been 2 (I think) guys with headgaskets and the greddy turbo kit, both of which have said its completely not worth it; you'll make less power then just boosting 10psi with stock compression.
As I've said before, this kit was designed for 300ish hp, NO more without upgrading the turbo and then at that point, why even bother with this kit?
Old Jul 21, 2008 | 06:34 PM
  #34
Series10's Avatar
because of the California Air Resource Board Executive Order Number
Old Jul 21, 2008 | 06:51 PM
  #35
TRBOKEV's Avatar
Its the ONLY reason I went Greddy instead of inline pro.
Old Jul 21, 2008 | 07:33 PM
  #36
brilliant's Avatar
well, my plan within the next 6 months is to run an aquamist kit and retune boosting 12 psi on stock compression.
i'll let you guys know how it goes.
Old Jul 21, 2008 | 10:26 PM
  #37
If you upgrade the turbo, you technically won't pass emissions anymore. The carb certification is for that particular turbo only...
Old Jul 21, 2008 | 10:45 PM
  #38
honda9krpm's Avatar
Could you post some more information?
Which headgaskets and engine managements were used? What was the boost after the headgasket installation? Is there any other mod?
Old Jul 22, 2008 | 08:36 AM
  #39
It was 3mm and emanage ultimate if I can remember. Not sure of other mods I would assume he had full supporting mods. He didn't even say how much power it made after the HG install and upping the boost because it was an "embarrassing number"
Moral of the story, be happy at 10psi and ~300hp. If your not, well you bought the wrong kit for anything more then 300ish hp.
Old Jul 22, 2008 | 08:37 AM
  #40
devs2k's Avatar
joey honestly...
sell the greddy kit, go inline pro
sounds like you got the wrong kit
