Guys I need help with turbo list
Which turbo are you using?
Have you found a tuner and consulted them? The Hondata unit has lots of capabilities, the unit has a built in boost controller output so all you need is the boost solenoid. They also sell their own map sensor that has a built in calibration and the O2 sensor.
I would not add the HPC coating, it is a temporary solution that will flake eventually.
Just relocate your factory battery, those little ones aren't very good for normal use.
Full Race Turbo Kit
Act HTG Clutch
Factory Flywheel
T1R 1000cc Injectors
Walbro 255L Fuel Pump
Fuel Pressure Regulator and Gauge
Supertech Inconel / Ferrea Valves
IP Valve Springs & Retainers
Valve Seals
ARP Exhaust Studs
Honda Head Gasket
Intake, Exhaust and Misc Gaskets
Hondata K-Pro
Hondata Boost Controller Solenoid
Hondata MAP Sensor
Battery Relocation kit
Your getting close, Good luck
Full Race Turbo Kit
Act HTG Clutch
Factory Flywheel
Valve Seals
ARP Exhaust Studs
Honda Head Gasket
Hondata K-Pro
Hondata MAP Sensor
Originally Posted by Reborn56,May 31 2009, 07:02 PM
Both my friends are trying out swain coating (dunno if that's how it's spelled)
I will let you know after they are up and running if it can handle the heat.
It only comes in white i believe tho
Marcus
Marcus
Personally, I think the white looks hot and am strongly considering doing my Mani/Downpipe/Dump with their White Lightning. Just trying to convince myself that:
1. I need it
2. I Can afford it
Seems like after shipping both ways and the coating that this could cost in the ballbark of $500 - ouch!
