Headgasket for 87.25mm ?
Old Aug 2, 2010 | 10:42 AM
siadam's Avatar
Default Headgasket for 87.25mm ?
I was going to order a h/g for the car today, and then realized, since it's over bored .25mm, a stock h/g won't work.
Where do you guys pickup your gaskets?
Thanks
Old Aug 2, 2010 | 10:54 AM
Irishflame27's Avatar
im pretty sure the OEM can be used no problem....
on my old b16 i over bored mine from 81mm to 81.25mm and used the stock HG with no issues
Old Aug 2, 2010 | 10:56 AM
siadam's Avatar
I wasn't sure the amount of overlap on the factory h/g..if there was enough space that it wouldn't hang over the cylinder wall.
I didn't pay attention to that when I took it off.
Old Aug 2, 2010 | 11:03 AM
adam i think your fine, possibly check with IP to make sure
Old Aug 2, 2010 | 11:10 AM
TRBOKEV's Avatar
Your only talking about .005" on each side of the cylinder, just use the OEM and you will be perfectly fine.
FYI a human hair is around .003 thick..
Old Aug 2, 2010 | 11:25 AM
siadam's Avatar
Thats good to know, thanks all.
bewareofthepoop
Feb 13, 2013 09:10 AM
OHclassic
Nov 12, 2012 05:56 AM
nipponS2000
Aug 23, 2012 04:09 AM
bois2k
Aug 18, 2010 08:12 AM
darkwatch
Jan 10, 2008 11:53 AM
