herecomesboost build thread (part 2)
Old Mar 7, 2013 | 04:06 AM
  #161
wy2slow_z's Avatar
that catch can setup should work fine. imo the best setup is on the other side with 2 fittings welded right behind the 2 metal flaps on the inside. doing this will stop access oil build up inside your can yet vent well.
Old Mar 7, 2013 | 05:50 AM
  #162
MrC@PTUNING's Avatar
Congrats on the purchase. We were wondering who uncle ron ended up selling the car to. Looks like it found the perfect home. Are you set on the PC680 lightway battery? We may produce a lightweight billet battery tray for the s2k for both the PC680 and PC925.
MrC
Old Mar 7, 2013 | 06:02 AM
  #163
sata3000's Avatar
MrC
What would look real good is the ptuning radiator brackets and cold air box.
Old Mar 7, 2013 | 06:08 AM
  #164
herecomesboost's Avatar
MrC
Thanks! I already have a battery tray on the way (but would be curious to see your option when produced): http://www.speedwaymotors.com/Micro-...Box,40580.html
Old Mar 7, 2013 | 06:09 AM
  #165
Originally Posted by sata3000
MrC
The airbox should be done this month. Waiting for the radiator shroud and airbox mounting base pieces from our vendor.
MrC
Old Mar 7, 2013 | 06:12 AM
  #166
Originally Posted by all4spl
I don't know if that catch can setup will work properly. I have same exact setup and when I have the lines connected, I get excessive smoking from exhaust and its blue "oil" I talked with precision and they said its evac setup related. I took the lines off and ran "open valve cover" and smoke damn near stopped.
Weird
Old Mar 7, 2013 | 06:43 AM
  #167
looksexyS2000's Avatar
I have the same catch can works perfect
Old Mar 7, 2013 | 07:05 AM
  #168
MrC
Here's a picture of our billet alum tray for the PC925 supplied with our tC2 turbo kit and also the PC680 tray used on the Evo 8/9. It's a complete tray that replaces the entire factory undertray. The battery is secured to the tray with 2x 3/8" SS bolts (3/8" bolts required by most drag racing sanctioning body).
MrC
Old Mar 7, 2013 | 07:38 AM
  #169
sata3000's Avatar
that looks sharp
Old Mar 7, 2013 | 08:10 AM
  #170
that looks sharp
x2
