herecomesboost build thread (part 2)
Old Mar 2, 2013 | 08:34 AM
  #141
liquidgsr's Avatar
Cool. Looks good. As always you have a outstanding setup in your garage and make great use of the space. I need to take notes.
Old Mar 2, 2013 | 03:31 PM
  #142
herecomesboost's Avatar
Thanks Nesar.
Old Mar 2, 2013 | 03:34 PM
  #143
Removed the emissions components:
Wires/relay(s)/fuse box are tucked in the fender(battery tie down is temporary):
I ordered 1/8--> -3AN fittings and -3 SS lines for the wastegate/boost solenoid (to replace the brass fittings/rubber lines)
Old Mar 2, 2013 | 04:58 PM
  #144
baZurk's Avatar
Good progress!
Old Mar 2, 2013 | 05:13 PM
  #145
Originally Posted by baZurk
Good progress!
Thanks Matt.
Old Mar 2, 2013 | 06:05 PM
  #146
liquidgsr's Avatar
Did you extend any of the wires. That tuck makes it look so clean.
Old Mar 2, 2013 | 06:31 PM
  #147
d-bo's Avatar
I have the BRM catch can too. wish it was a little different so you didn't have to go over/under the radiator hoses. i have my radiator hose tapped too but a bit behind the alternator. def a lot of things going on in that area now lol
although mine looks like crap right now, putting the fusebox and eps in the fender really clears out a ton of room. i moved my battery to the trunk so that helps a bit too, but at least you have a small battery.
Old Mar 2, 2013 | 07:04 PM
  #148
miguel329's Avatar
Originally Posted by herecomesboost
Originally Posted by liquidgsr' timestamp='1362196921' post='22374577
I like the heat shrink idea. I might have to try that when I finish. Looks good Kyle.
Thanks Nesar. Just swing by my house when your car is up and running; we can heatshrink the hose end on your car.
I like the heat shrink idea! I been trying to figure out what I wanted to do for that side of of valve cover. But I'm using nylon braided line hate ss lines
Sent from my SPH-L710 using Tapatalk 2
Old Mar 2, 2013 | 07:19 PM
  #149
liquidgsr's Avatar
I have spare as line but thinking to use that or order more nylon. I'm all out of nylon.
Old Mar 2, 2013 | 07:21 PM
  #150
liquidgsr's Avatar
Also how did you tuck the passanger side line. I might look into that at one point.
