herecomesboost build thread (part 2)
I have the BRM catch can too. wish it was a little different so you didn't have to go over/under the radiator hoses. i have my radiator hose tapped too but a bit behind the alternator. def a lot of things going on in that area now lol
although mine looks like crap right now, putting the fusebox and eps in the fender really clears out a ton of room. i moved my battery to the trunk so that helps a bit too, but at least you have a small battery.
The lines are running through the hole in the frame where the washer bottle used to reside (using a grommet on the hole to protect the wiring)
Definitely. This was more of a 'proof of concept' (how to mount the fan/oil pump relays). I've decided to delete the splash guards, so I'll be relocating the fuse box accordingly.
I don't know if that catch can setup will work properly. I have same exact setup and when I have the lines connected, I get excessive smoking from exhaust and its blue "oil" I talked with precision and they said its evac setup related. I took the lines off and ran "open valve cover" and smoke damn near stopped.
Sent from my iPhone using Tapatalk
