herecomesboost build thread (part 2)
How many lbs your wastegate spring? You may need a stiffer wastegate spring to hold to redline.
Currently I am experimenting with the 4port Mac solenoid boosting to 25psi. Goals is to hold 25psi to redline. One difference I notice is boost comes on faster resulting in more torque. The duty cycle on the 4port is very sensitive. A small change in the duty cycle can result in a huge boost oscillation to red line. It was critical to find the exact duty cycle for the boost level. Unfortunately, I got tired of doing runs by myself, so I had friend drive so I can optimize the duty cycle quicker. A 4th gear pull was too much for him to handle, the rear end spun sliding towards a telephone pole and we bounced back onto the road. Just a damaged bumper, a tail light, and a rim. Got everything replaced and just waiting to put on a new set of fresh tires and see if it still runs straight. Be safe. 25psi is too much to handle on crappy tires.
hey kyle looking good man !!!!! just chiming in on the fuel wicking.... your not worried ? Im thinking of a walbro 400 as well but am worried about the install, (not my ability but the fuel wicking) you thinking all is good ?
-Lee
-Lee
Hey Lee. Thanks dude! The likelihood of that happening (fuel wicking) is minute, in my opinion. My initial plan was to drill holes for two studs, but there simply isn't a good place for them (the bottom of the fuel hangar mount is not flat; no good place to mount a bolt/nut).
