herecomesboost build thread (part 2)
Old Aug 30, 2013 | 08:52 AM
  #621
liquidgsr's Avatar
I'll let you know how the sensor works out when I get it installed if you haven't installed it by then yourself. Also if your looking for a upgraded fuel pump I have a walbro 400 already installed in a hanger ready to go in off of a 2005, it wouldn't fit my car so I ended up going with the fb dual 340s and id2k.
Old Aug 30, 2013 | 10:14 AM
  #622
OHclassic's Avatar
What's the deal with returnless vs return fuel system and E85 and why would choose one vs the other?
Any issue with fuel starvation, 600+ whp under WOT ? Or no issues ?
Old Aug 31, 2013 | 11:47 AM
  #623
WootRWD's Avatar
Looking do bad ass. Can't wait to see you turn the boost up man. Things going to be a beast.
Old Sep 7, 2013 | 04:14 PM
  #624
herecomesboost's Avatar
It will be another week or so before my sensor arrives (back ordered currently). I'm likely going with the Walbro E85 (~450lph) pump; thanks though
I believe the ability to maintain fuel pressure is the main issue with high boost setups (that are returnless).
Thanks man!
Decided to make the trek to College Park (Maryland) to pickup an OEM (style) carbon fiber hardtop; fits perfectly. My Zietronix Fuel Content display, GM fuel content sensor, and carbon fiber trunk should arrive within the next few weeks. Then I'm off to Ashburn (closet E85 station) to fill up and test the new flex settings.
Old Sep 7, 2013 | 04:33 PM
  #625
WootRWD's Avatar
Son of a bitch. I like these more than my oem hardtop.
Pretty light weight? I'm jelly dude
Old Sep 7, 2013 | 04:39 PM
  #626
liquidgsr's Avatar
Hard tip looks great.
Old Sep 7, 2013 | 05:06 PM
  #627
Yeah. I'm a big fan of the OEM body lines; the fact that it's (double sided) carbon fiber is a bonus Not sure how much it weighs, but it's VERY light.
Hard top looks great.
Thanks Nesar!
  #628
riceball777's Avatar
I am also very interest in you running the flex fuel sensor and being able to run e85 with out swapping maps or draining the tank of pump gas.
I'm also running id1000's. On stock fuel pressure they are at 60% or so at 440whp on pump gas and 100% at 500whp and e85.
With e85 you really need 2000cc injectors and either a walbro e85 450 or a dual pumper.
take some pics if you can when you install the walbro 450 in the hanger so we can see how it fits and what is needed to make it work.
Old Sep 7, 2013 | 05:08 PM
  #629
WootRWD's Avatar
Long story short, efficiently you will. There's no cheap way out of e85 unfortunately
Old Sep 7, 2013 | 05:18 PM
  #630
My flex map is running ~30% more fuel currently. The beauty of the (dynamic) flex capability is that the maps will blend based on ethanol content (based on how you have your blend% vs. fuel content% configured; currently mine is set to 0 blend at 10% ethanol and 100% blend at 85% ethanol, with the two points interpolated, creating a linear relationship). 'blend' being the blending of the two maps (not the fuel blend). I'll likely start somewhere around the E65-70 point since I'm not draining the 93 from the tank.
My current duty cycle is 63% (15psi) running the factory base fuel pressure (~43psi). I'll definitely upgrade to larger injectors in the near future. In the interim, if I'm approaching a duty cycle that I feel uncomfortable with, I'll keep the boost lower on the E85 (flex) map. iirc, you were at 17psi when you maxed your ID's at 500whp/E85?
I'll definitely post pics of the new pump installation.
Agreed.
