hi hp guys and traction?
Old Jan 7, 2014 | 06:57 PM
p0staboy's Avatar
who has used nt01? I heard they have good traction
Old Jan 7, 2014 | 08:17 PM
Phill24's Avatar
i believe passman run nt01s.......op i run kumho XS 275/40/17 after about 5 minutes of driving they hold really good @ 706hp
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Jan 8, 2014 | 01:11 AM
9k all day's Avatar
I would also like to know what high hp guys are running for tires. Im shopping for a new set right now. Im planning on running a square set of Enkei PFO1ss 17x9 +60 but don't know what tires to put on them !?!?!??!
Old Jan 8, 2014 | 03:38 AM
Phill24's Avatar
Thats what i have on my car 235/45 17 up front 275/40 in the rear
Old Jan 8, 2014 | 04:40 AM
d-bo's Avatar
i think you're going to need anything 255/40 and larger to have any decent traction. i wouldn't expect any traction under 40mph unless boost is limited
my friend has a 500hp/450 tq sr20 240sx with toyo R1R 275/40/17 and they hook up pretty good from a 40 roll
other friend has a ls1 240 and he hooks up from a 40 roll with 600hp/600tq on spray from a 40 with NT05R 275/40/17
Another friend has the Toyo R888's on his cobra that makes like 700hp/800 ft lbs but they're 295's or something but he doesnt spin
it's all about contact patch and if you have a little bit of a softer sidewall. you're gonna spin every where with a hard thin sidewall
Old Jan 8, 2014 | 05:49 AM
blixhavn's Avatar
I ran nt05 on my 16psi charger, love the tire til 50% tread life, then it seemed to never be able to hook. I was at 377 rwhp, bumping to a turbo this year and I definitely wouldn't recommend NT05. I'll look into mickey T's next but thought I'd throw my opinion out there on nt05.
Old Jan 8, 2014 | 06:33 AM
beaudin223's Avatar
mickey thompson are the best to hang some serous power , the only bad thing about thistire its when you see some rain its horible , its hang 0%
Old Jan 8, 2014 | 04:24 PM
passmans2kny's Avatar
the nitto nt01s exceeded my expectations, i couldnt believe how well they hook in the lower gears, granted i have a 3.9 diff gear
Old Jan 8, 2014 | 04:48 PM
boostedf22c's Avatar
Mickey radials are the way to go, and boost vs vss to control power application.
Old Jan 9, 2014 | 06:40 PM
pettyboy69's Avatar
Mickey Thompson makes what they call their drag radial II, they are a soft rubber drag radial made for big wheels that are lower profile but still work awesome. They are made of the same compound as their regular drag radials just less sidewalk for bigger wheels. My bros corvette has them on stock z06 wheels and they work amazing, cuts 1.7x 60ft at the track and the same on the street, no slipping at all but his converter helps with that too
Alexander Startsev
Sep 24, 2016 12:27 PM
Mar48
May 11, 2012 06:15 PM
Ludicrous Speed
Feb 15, 2010 06:53 PM
StarvinMarvin
Apr 26, 2007 06:16 PM
FairfaxRev9k
Aug 18, 2005 09:32 PM
