How to hook up a timing light
Old Oct 12, 2010 | 09:33 AM
jb34304's Avatar
Default How to hook up a timing light
I am trying to set the timing on my car. I try to get it connected to the cord going to the first coil (closest to bumper), but the wires are too close to the next coil, and it has an incomplete connection. I get the occasional flash every 5 or six seconds. Any ideas?
Old Oct 12, 2010 | 11:35 AM
Sideways's Avatar
There is a several inch loop in the bundle of wires at the back of the engine where you can pick up signal for the timing light.
Old Oct 12, 2010 | 04:16 PM
jb34304's Avatar
Ok I see it now thanks.
Josh
Old Oct 12, 2010 | 04:41 PM
dsddcd's Avatar
Be careful if you hit the poer or ground you will read Dweel not timing.
I would suggest that you make a smal plug wire to go from your coil to the plug and put the clamp around that.
Old Oct 12, 2010 | 06:26 PM
R1_Pilot's Avatar
How are you going to adjust timing? Can you even measure the timing on this car?
J
Old Oct 12, 2010 | 06:52 PM
Seattle2k's Avatar
J
Yes, you can read the timing. The crank pulley has markings.
https://www.s2ki.com/forums/index.php?showt...0&#entry3043000
Evans Tuning also mentions using a jumper wire between the coil and plug.
https://www.s2ki.com/forums/index.php?showt...&#entry19448484
Old Oct 13, 2010 | 06:57 AM
dsddcd's Avatar
J
This is an important step to setting up an AEM EMS. You need to sync the timing so that the spark and fuel are intiated at the correct time.
Old Oct 13, 2010 | 08:19 AM
jb34304's Avatar
[QUOTE=Seattle2k,Oct 12 2010, 06:52 PM] Yes, you can read the timing.
Old Oct 13, 2010 | 11:26 PM
Seattle2k's Avatar
Ask Evans.
Old Oct 14, 2010 | 03:02 AM
AusS2000's Avatar
I take the coil pack off the cylinder 1 spark plug and run a high tension lead between them. I clip the sensor around this.
dsddcd
Mar 2, 2018 03:33 PM
03silver2000
Jan 26, 2009 05:06 PM
s2k_PikeStyle
Jun 21, 2006 09:53 AM
timg
Aug 27, 2004 07:31 PM
