IAT Sensor - pics
Old Nov 27, 2006 | 02:32 PM
  #21
Slows2k's Avatar
Good question.
I guess they don't think it's as important as all OEM manufacturers that use them.
Old Nov 27, 2006 | 02:38 PM
  #22
2QYK4U's Avatar
Originally Posted by Slows2k,Nov 27 2006, 03:32 PM
Good question.
Well, I will still be utilizing it so it is all good!
Old Nov 27, 2006 | 04:36 PM
  #23
Phillie's Avatar
I was told to get a GM Iat and have a bung welded to the charge pipe also. Where do you buy these GM parts from other then Cheverolet. <bad joke.
Old Nov 27, 2006 | 05:08 PM
  #24
hboy7777's Avatar
i had to switch out my iat for a honda obd1 iat sensor. there was a problem with the ems reading it. has anyone ever heard of this?. one of the best tuners in the country did it and said he has to do it on all the s2000's he does.
Old Nov 27, 2006 | 05:09 PM
  #25
2QYK4U's Avatar
The shop that I use told me that Honda makes a threaded IAT sensor. I'll let you know what the part number is as soon as they tell me.
Old Nov 27, 2006 | 05:12 PM
  #26
Phillie's Avatar
Thanks Justin! I'll be towing my car down to So. cal week before x-mas hopefully everything will be done.
Old Nov 27, 2006 | 05:20 PM
  #27
2QYK4U's Avatar
Towing your car to So Cal? What is that all about? What all have you installed on your S2000 thus far?
Old Nov 27, 2006 | 07:35 PM
  #28
Phillie's Avatar
[QUOTE=2QYK4U,Nov 27 2006, 06:20 PM] Towing your car to So Cal?
Old Nov 27, 2006 | 07:43 PM
  #29
Phillie's Avatar
Basically I have to finished connecting all the hoses to the turbo, IC piping, exhaust, intake, IAT, fuel pump, install gauges, and put the car back together.
I want to tow it because 400 miles is alot of miles for something to break and be stuck if I can't fix it on the spot.
Old Nov 28, 2006 | 01:34 AM
  #30
racecarpete's Avatar
It's not necessarily bad to run the IAT just dangling. It just will read a little warmer. You could just try to drill a hole in the charge pipe, install a rubber grommet and put the sensor in. Then dab a little silicone sealant around to keep it nice and snug but I would constantly worry about it.
Phillie I sent you a pm.
