if using a catch can do you keep the pcv valve?
Old Aug 3, 2013 | 05:43 PM
GrandMasterKhan's Avatar
Default if using a catch can do you keep the pcv valve?
I have heard conflicting opinions on this subject.
When using a catch can. Do you keep the OEM pcv setup? (running from the Pcv port over to the intake manifold)
Old Aug 3, 2013 | 06:02 PM
tx2K's Avatar
Mines not... I just set it up using the stock ports going to the catch can.
Old Aug 3, 2013 | 06:20 PM
s2knoob89's Avatar
No, it's not needed especially with the increase in crank case pressure from being boosted.
Old Aug 3, 2013 | 07:57 PM
cool. thanks guys!
Old Aug 3, 2013 | 08:25 PM
I have some seen some people still use the OEM pcv setup when they have a catch can. why would they do that?
Old Aug 4, 2013 | 07:43 AM
camuman's Avatar
Depends where your lines are. If none of the ones run from pressurized side of intake to valve cover then not needed. But in part throttle situation you can use the vacuum from intake to suck air out of crank case. Then when you go into boost it closes.
Old Aug 8, 2013 | 01:59 PM
Boofster's Avatar
I think all PCV does is keep the flow in one direction. (Positive Crankcase Ventilation)
Since the catch can does not have any reason to push flow back, the PCV doesn't matter.
If you remove it, you simply get more venting.
On the AP2, it's simpler to just swap out the PCV fitting with a hose fitting to make things nice
Old Aug 8, 2013 | 05:33 PM
herecomesboost's Avatar
Not needed with a catch can
jordannn93
Sep 21, 2012 01:32 PM
AP1Driver
Jun 5, 2012 07:15 AM
s2konroids
Jan 25, 2011 06:53 PM
AllStock27
Jul 10, 2005 04:30 PM
