If you have a TURBO, GET RID OF THE CAT!
Originally Posted by ZSAK,Apr 2 2008, 04:35 PM
how much of a difference would the test pipe make compared to a hi flow cat?
I've got the Berk 2.5" high flow cat and it made a huge difference vs the stocker.
can emanage setup a Load Limiter like the EMS? I know the limiter has saved my motor at least 2-3 times due to loosening bolts, wastegate lines being cut, colder weather etc... If it doesnt, maybe setting up some sort of boost sensor that plugs into the ECU to cut out ignition or fuel... maybe something that ups the voltage on the knock sensor input to decrease timing, or just turn the car off, albeit crude, it would save alot of rebuilt motors from happening!
However, I don't think the ULT can change the main rev limiter so I would have a hard time seeing it add in a secondary rev limiter. Who knows?
yes the ultimate can change your main rev limiter under the Rev Limiter Cut setting if the factory rev limiter is a fuel cut, won't work if it's an ignition cut.
You can set a safety for this overboosting situation as well. In the Airflow Adjustment Map you have RPM running along the top and pressure on the side. What we did for example, was at .90 kg/cm
s2k_bmich510
Dec 14, 2007 06:19 PM
