Increased boost
Old May 17, 2006 | 12:50 PM
Headchef's Avatar
Active Streak: 30 Days
Default Increased boost
I am planning to go to 7-8lbs boost on my Ap1. using comptech pulley and belt. Do I need to do any other engine mods or will I be okay at stock settings for the comptech kit?
Old May 17, 2006 | 03:59 PM
r_duff's Avatar
7 lbs max on stock setup. u might look into cooler plugs. check the NGK 7131 or the 7405
Old May 17, 2006 | 04:23 PM
Headchef's Avatar
Thanks r duff ! What's the next step if I go higher boost yet?
Old May 17, 2006 | 04:26 PM
r_duff's Avatar
im doing the same thing. i ordered a 3.85'' pulley from ASPracing. it should put out about 7.5 psi (i have the aftercooler, so im expecting a .5lb loss in boost). I also just ordered the 7405 ngks from kragen and a 39'' gatorback belt from autozone. Also u need to dyno it to make sure your A/F ratio is safe.
Old May 18, 2006 | 10:24 PM
FF2Skip's Avatar
I use 7173's.
As for going to 7#, I strongly suggest hitting up a tuner immediately after install. They can't do much more than adjust the Comptech fpr, but chances are you'll be running lean out of the box and will need that adjustment.
After that, check your plugs frequently. Good luck and have fun.
Old May 19, 2006 | 06:55 AM
Venomous S's Avatar
sounds to me like you have a thing for plugs
Old May 19, 2006 | 11:14 AM
r_duff's Avatar
Originally Posted by FF2Skip,May 18 2006, 10:24 PM
I use 7173's.
i will be putting the pulley on tonight and driving church auto on sat
bublik
Sep 5, 2008 07:57 AM
gusrock77
Mar 23, 2006 05:18 PM
Nick32
Oct 5, 2005 06:29 AM
jlangton
May 11, 2003 08:31 PM
SpoonS
Mar 20, 2003 11:38 AM
