inline pro oil relocation question
Old Nov 2, 2008 | 12:06 PM
TelosHedge's Avatar
Default inline pro oil relocation question
so we're working on the car its time for the relocation.
the filter side fits perfect, no problems. the block side has a bit of play in it though. we've got the big huge bolt down pretty tight but the actual adapter can still rotate up and down - though it is up against the block flush.
we removed the stock oil cooler and used an o-ring gasket on the block side adapter. is this correct? is a little bit of play ok? we figured it should be pretty tight on and almost impossible to turn.
please advise
Old Nov 2, 2008 | 04:33 PM
otbs2k's Avatar
In order for it to fit snug, you'll have to take the bolt out and trim about a 1/4 inch off of it. Sucks, but it's pretty common for this relocation kit.
Old Nov 2, 2008 | 04:55 PM
03silver2000's Avatar
idk the situation but could you just build the bolt up with washers?
Old Nov 2, 2008 | 06:39 PM
TelosHedge's Avatar
pretty sure that's what we're going to do tomorrow.
the only problem with this method is that if i go too crazy with washers the banjo bolt hole will not line up properly. i will let you know what happens tomorrow!
Old Nov 2, 2008 | 09:05 PM
Kirpich's Avatar
No, not washers. The problem is the bolt is simply too long. It won't let the o-ring seal properly because it won't let the adapter come close enough to the block to compress the o-ring enough to make it seal. cut a few threads real careful-like.
Old Nov 2, 2008 | 10:33 PM
otbs2k's Avatar
Old Nov 3, 2008 | 09:00 AM
gotswap's Avatar
I am able to rotate mine with a bit of force and it does not leak at all.
Is yours loose to the point you can just spin it?
Old Nov 3, 2008 | 12:41 PM
TelosHedge's Avatar
i fixed it. i was taking a gander at the pictures of the kit on ILP's website. i saw an o-ring that i didnt have.
quick trip to home depot and the piece tightened right up!
so now, onto the next problem!
check the FI forums for my continuing progress
cheddaboy
Oct 22, 2014 12:17 PM
rikhemi
Nov 6, 2010 07:31 PM
s2k54
Nov 22, 2008 03:27 PM
DEIGER
Aug 12, 2007 05:45 PM
cheshire_carper
Sep 3, 2005 02:20 AM
