inline pro tct
Old Jul 27, 2012 | 01:28 AM
  #31
sata3000's Avatar
Would that oil be ok for me? some weeks I dd the car. Im currently using amsoil.
Sent from my Galaxy S II using Tapatalk
Old Jul 27, 2012 | 05:37 AM
  #32
passmans2kny's Avatar
Originally Posted by sata3000
Would that oil be ok for me? some weeks I dd the car. Im currently using amsoil. Sent from my Galaxy S II using Tapatalk
amsoil may be a little better, but you can run the mabil 1 turbo diesel all day, I get it bc it has good zddp levels and I can get it on amazon
Old Jul 27, 2012 | 06:56 AM
  #33
camuman's Avatar
amsoil here, 10w40. motor is def quiter with it vs mobile 1. never ran diesel oil though. i thought my tct was going bad, then realized it was my mac boost control solenoid ticking lol.
Old Jul 28, 2012 | 04:06 AM
  #34
B5254T4's Avatar
Also looking for a TCT, I think Tomei got an upgrade and maybe Skunk2 if the K-series work.
Maybe time for a GB?
Old Jul 28, 2012 | 07:04 AM
  #35
o'malley_808's Avatar
just sandblast the worm gear and use a better oil. No need for a new tct
Old Jul 28, 2012 | 10:19 AM
  #36
B5254T4's Avatar
I´m building a new engine and want a new TCT, that´s why.
Old Jul 28, 2012 | 11:03 AM
  #37
Phill24's Avatar
Originally Posted by passmans2kny
Originally Posted by JoeyBalls' timestamp='1343352127' post='21892474
[quote name='Spoolin' timestamp='1343350390' post='21892432']Oil without high ZDDP is more than likely the culprit to the TCT's going bad. I've always run good Amsoil with very high ZDDP and not one problem out of mine. Although the car only has 16k original miles. LOL
Yup, this why I use Mobil 1 Turbo diesel
as do i
[/quote]
mobile 1 turbo diesel 5w 40?
Old Jul 28, 2012 | 12:41 PM
  #38
yes sir, little update on my issue, did leak down test, every cylinder is good, valves seem fine, when I run the car it seems the ticking is coming from inbetween cylinders 2-3, I am wondering is the sound from the tct just seems like its coming from there, resonating through the engine, or if i have another problem altogether, car is already in pieces again(cams off, next manifild and turbo stuff to get to the pos tct), will install the new tct next week and see if that has fixed my ticking, I am thinking maybe I cracked a timing chain guide, or it could just be the tct(hopefully)
Old Jul 28, 2012 | 02:03 PM
  #39
Wydget's Avatar
Is 5w40 to thick for Texas heat? I was thinking of switching over but I'm a little hesitant.
Old Jul 28, 2012 | 02:52 PM
  #40
Im running mobil1 15w50 in Toronto. Highest zddp levels found out of any of the Mobil 1 oils.
A new tct will not fix the problem. I've spent the $240 on a new tct just to have it fail again. Switch oils and sandblast the worm gear and be done with it.
