InlinePRO setup version 2.0
Old May 9, 2007 | 09:27 AM
  #51
2QYK4U's Avatar
Originally Posted by geists2k,May 9 2007, 09:59 AM
He did it with the EMS by using VSS and sampling engine speed in each gear.
I make 10 psi in first gear blending to 12.5 psi in second gear and by the top of third I'm making 16 psi.
We did about five 1st gear through 4th gear pulls and it works really well.
No tire spin or traction issues at all.
That is interesting. I am making 10 psi in both 1st and 2nd gear and at WOT the tires (RT-615s) go up in smoke.
Old May 9, 2007 | 09:29 AM
  #52
geists2k's Avatar
What are RT-615's? What size?
Old May 9, 2007 | 09:33 AM
  #53
geists2k's Avatar
Oh Falken AZENIS RT-615.
Don't know much about those. My BFG's are pretty sticky.
Old May 9, 2007 | 09:38 AM
  #54
2QYK4U's Avatar
[QUOTE=geists2k,May 9 2007, 10:29 AM] What are RT-615's?
Old May 9, 2007 | 10:50 AM
  #55
slimjim8201's Avatar
What are you using to control your boost. I like the gear dependent boost settings...
Old May 9, 2007 | 11:12 AM
  #56
geists2k's Avatar
I had a GM boost control solenoid and after about ~6 months it stopped controlling the boost.
We had boost on pump gas set to 12.5 pounds due to the over boosting issues before putting in the built motor and I would consistently boost up to 16 psi.
Not cool.
I replaced the GM with the AEM boost controller and so far, it works perfectly.
I like the AEM piece a lot better because it seems higher quality. At least it is made of metal.
1SlowSi
Mar 4, 2014 10:34 AM
stantaur
Mar 19, 2008 08:18 PM
pushin9
Apr 5, 2007 05:49 AM
wildcardtrd
Feb 9, 2007 05:36 AM
bc02
Sep 19, 2005 08:36 AM
