Inspection trouble in NC. Please help!
Old Jan 12, 2010 | 02:03 PM
  #21
goldsS2000's Avatar
Originally Posted by ECale3,Jan 12 2010, 01:29 PM
Will a setup with the stock ECU and an e-manage throw a CEL if things like the air pump or secondary 02 sensor are missing?
Im actually unsure about that air pump question but I know the absence of an O2 sensor will throw a code, and Im pretty sure the emanage shouldnt cause any to pop up. On your air pump removal did you just get an egr blockoff and plug your vacuum lines? Ill be doing the same thing and was wondering the consequences of that as well
Old Jan 12, 2010 | 03:02 PM
  #22
TRBOKEV's Avatar
Yes it will throw a code.
Old Jan 12, 2010 | 05:56 PM
  #23
Artisan7471's Avatar
If you think its bad now, just wait untill Obama passes his cap and trade, all states will then be required to adopt California style emissions standards! Talk about a pain in the ass.
Old Jan 12, 2010 | 05:58 PM
  #24
QuagmireS2k's Avatar
It won't pass though. Well crap hopefully.
  #25
wes87's Avatar
ya for cali emission standards country wide......hate this state sometimes lol
Old Jan 12, 2010 | 09:06 PM
  #26
ECale3's Avatar
I have an ems so it was all simply removed.
Old Jan 13, 2010 | 04:19 AM
  #27
goldsS2000's Avatar
Well yes I know you can clear the cel from the absence of the air pump with the EMS but I wanted to take it out while I was on stock ecu before I put everything on the car. Because if I cant, Im going to have to bolt that hoe back up next year when the car needs inspected again
Old Jan 13, 2010 | 04:56 AM
  #28
CaseyGW's Avatar
do you not have any friends that have their inspection license?
Old Jan 13, 2010 | 07:30 AM
  #29
wadzii's Avatar
Banned
go get some peak/hold rc370ish cc injectors so you dont have to remove the resistor, the car likely wont run with stock injectors + resistor box.
You should be able to use a couple spark plug defoulers to keep the lack of a cat from throwing a CEL, get the air pump delete kit and you should be fine.
Most people arent too interested in the visual inspection, that'd be all you had to worry about was them actually looking under the car for a cat.
Old Jan 13, 2010 | 09:10 AM
  #30
CaseyGW's Avatar
or make some new friends
