ITB for Turbo
Old Mar 21, 2007 | 08:22 AM
  #41
smitdog's Avatar
WOW.
Old Mar 21, 2007 | 08:26 AM
  #42
2QYK4U's Avatar
Originally Posted by fperra' date='Mar 21 2007, 08:15 AM
Yes, 50/50 water-meth direct port using the latest Aquamist setup.
Very nice! I am thinking about going with that same setup.
Old Mar 21, 2007 | 08:41 AM
  #43
S2_PHENOMENON's Avatar
That is a very nice Manifold!
Old Mar 21, 2007 | 08:53 AM
  #44
Tyraid2K's Avatar
I can't wait to see results, it will be hard to tune for sure.
I've been dreaming of doing this for awhile so im going to follow this closely
Old Mar 21, 2007 | 09:03 AM
  #45
fperra's Avatar
I don't think the tuning will be that hard at all. It still will be using a MAP sensor. I'll probably switch from the GM 3 BAR to the AEM 3.5 BAR. It will make for a cleaner install. Since I won't be using an IAC, the hardest part will be the cold start. I'll probably just have to live with that unless I opt for adding an IAC.
Old Mar 21, 2007 | 09:07 AM
  #46
Venomous S's Avatar
Originally Posted by fperra' date='Mar 21 2007, 09:54 AM
The biggest advantage is better throttle response and more low to mid range power. As far as reduced flow goes, a single 3 inch throttlebody has a cross sectional area of 7.065 sq. inches. Four 50mm throttlebodies have a total cross sectional area of 12.16 sq. inches. And the stock throttle body is less than 3 inches.
These numbers defenitely speak for themselves. Interested to see some dyno chart comparisons
Old Mar 21, 2007 | 09:09 AM
  #47
MugenRioS2k's Avatar
Old Mar 21, 2007 | 09:17 AM
  #48
VeilsideAP1's Avatar
Sick.
Old Mar 21, 2007 | 09:35 AM
  #49
5thelement's Avatar
you sir are a pimp.... loving that itb set up
Old Mar 21, 2007 | 09:51 AM
  #50
c_me_go's Avatar
can you only run Meth with water?? or can you use meth like a dry shoot and spray it into the Intake Mani?
