Just TWO Comptech Questions
Old Jan 31, 2005 | 09:38 AM
Bane's Avatar
I've used ACT clutches in all my cars in the past with good results.
If I were to do it, I'd use an ACT heavy duty pressure plate, OEM Honda friction disc, OEM Honda throwout bearing, ACT clutch alignment tool, and a TODA lightweight flywheel.
*edit* Forgot pricing
Clutch is probably ~$350
Flywheel is ~$400
Install is likely $500
So you're looking about $1250 for the drivetrain upgrades (I like to guess high whenever I'm going to mod my car so don't flame me please )
You can use the stock flywheel and get it resurfaced for about $50... it'll save you about $350 as well.
Old Jan 31, 2005 | 09:44 AM
73Zero's Avatar
[quote name='600rr_rocket' date='Jan 30 2005, 05:18 PM'] Hmm...which clutch brand do you guys recommend?
Old Jan 31, 2005 | 12:37 PM
600rr_rocket's Avatar
Ok, this is turning out more expensive than I expected but I really would love the extra power.
Cost breakdown (quoted from a local installer):
ACT Pressure Plate, OEM disk, OEM throwout bearing, and Comptech Flywheel - $1,000
Comptech SC w/ aftercooler - $6,000
Labor - $900
Total - $7,900
Is this a good deal, or should I try and bargain down?
Thanks.
Old Jan 31, 2005 | 01:04 PM
73Zero's Avatar
Labor - $900
Total - $7,900
Thanks.
A $900 labor charge? Does this include the install fee for both the S/C and the clutch? If so, I'd say that's a damn good deal...
Old Jan 31, 2005 | 01:05 PM
nibble's Avatar
Old Jan 31, 2005 | 01:09 PM
revhi's Avatar
$6000 for S/C aftercooler? You can get it cheaper online or from hardtopguy.
Old Jan 31, 2005 | 02:08 PM
Yeah, the $900 labor is for SC w/aftercooler + Clutch + Flywheel installation. The prices for the parts may be cheaper online, but if I purchase them through the installer, they can discount their labor.
So $7,900 is a good deal? I shouldn't try and squeeze another hundred bucks or so? I'm itching to call them to set up my appointment...(again I promise before & after dyno charts posted on this site)
Old Jan 31, 2005 | 08:04 PM
Bionic Man's Avatar
Where are you located? If you are West Coast then Spugen (AHHVTEC) would be the place to go. If you do a little research you will see that several places have the S/C for about $800.00 cheaper. Also your stock 2004 will not be much louder after the S/C install. Good luck!
Old Feb 3, 2005 | 12:56 PM
hydeaway's Avatar
this is where i got my SC http://www.superchargersonline.com/index.asp
Old Feb 3, 2005 | 01:44 PM
Honda_mann's Avatar
www.harptopguy.com
#1 in comptech goodies
ronaldng0809
Feb 16, 2007 07:18 AM
Axel6
13
Jan 16, 2006 08:16 PM
GotRPMs
Oct 26, 2005 07:34 PM
wdavis
Feb 25, 2004 05:06 PM
Daremo
Feb 5, 2002 09:43 PM
