Kit has finally been completed.
Old Dec 20, 2009 | 03:44 PM
  #51
Moddiction's Avatar
Former Sponsor
I think I have the bolts already as I previously ordered all the missing hardware to bolt the sc on to the engine so should have it. I will make sure however.
Do you know for sure what it is called on the parts list or the part number for that bracket part?
Old Dec 20, 2009 | 03:48 PM
  #52
Sideways's Avatar
Originally Posted by Moddiction,Dec 20 2009, 05:17 PM
Is it labeled as the lower sc plate spacer?
I see that listed in one picture in figure 8-O
but in the one you listed it is called a sc plate mounting block.
For ordering not sure which one is the correct one. Or maybe they are just called two things but are the same?
Oh and also I just noticed that there is a filter in the install manual coming off the bov or bypass valve. Is that needed?
Yes. It is the lower super charger plate spacer with the round protrusions to be mounted against the front cover.
The filter is for CARB. Because there is a blow by tube that enters the intake air passage there is the possibility the air has some oil vapor in it. The filter is to keep the vapor from leaving the intake. Smog considerations aside, it is not necessary.
Old Dec 20, 2009 | 03:50 PM
  #53
Moddiction's Avatar
Former Sponsor
Ok great! Thanks a lot. 1 more question sorry haha.
Is this hose supposed to be cut like this? If so where does it go to or do I need anything for it?
Old Dec 21, 2009 | 09:19 AM
  #54
Moddiction's Avatar
Former Sponsor
Ok just ordered that bracket part from Vortech. Thanks.
Guess I needed the super long threaded bolts as well so got the two of those with the nuts.
Cost like $40 plus shipping but the person who sold me the partial kit said they would just refund me the cost as it was supposed to be included with the purchase so that's good.
Old Dec 30, 2009 | 02:44 PM
  #55
Moddiction's Avatar
Former Sponsor
Got the missing bracket part and hardware in. Still don't know about that vacuum line that's cut above. Anyone know?
Old Dec 30, 2009 | 04:04 PM
  #56
Moddiction's Avatar
Former Sponsor
Oh also does anyone know what type of bung or whatever I need for the oil return line and what I can buy to cap it off when not connected to oil line?
Old Dec 30, 2009 | 05:40 PM
  #57
Sideways's Avatar
If it won't reach the intake manifold add another piece of hose.
I welded mine and tapped it.
Old Dec 30, 2009 | 06:02 PM
  #58
Moddiction's Avatar
Former Sponsor
Yeah I'm going to have someone weld the bung in but I need to supply both the bung and the cap to close it so not sure what size one I need and all.
The hose goes inside the box and can't see where if connects. Can I just open the black box.
Old Jan 4, 2010 | 05:40 PM
  #59
Moddiction's Avatar
Former Sponsor
So what size bung and cap would I need to get to have welded onto the oil pan for the return line?
I am having the banjo bolts put in shortly so want to have a bung to have welded on while the oil pan is off anyways so I don't have to change my oil again in a week or two.
Need the bung and a cap so I can cap it off until I have the sc installed.
Old Jan 4, 2010 | 05:42 PM
  #60
Moddiction's Avatar
Former Sponsor
Do you know what size of one that is? Thread and width and all? Need one to fit the Vortech return line tap part.
