Kraftwerks C38-91 stripped threads
Old Aug 16, 2017 | 09:55 PM
Ivanaguilar's Avatar
Default Kraftwerks C38-91 stripped threads
Hello again everyone,
Yet another issue with my Kraftwerks kit with upgraded C38-91. I seem to have solved the vtec solenoid bolt issue by using grade 12 Allen-head bolts instead of the grade 10 that came included with the kit, those have been giving me no issues whatsoever, except now it seems that somehow, the bolts holding the supercharger pulley onto the rotrex unit (6 small Allen-head bolts) backed themselves out and in doing so, stripped the threads on the small plate of the Rotrex blower, which then also shredded the belt a bit (still intact). I bought new bolts and used a fresh coat of loctite and torqued them down but it just did the same thing again and I am now stumped. Has anybody else had this issue or know of a solution? I plan on opening a support ticket with Kraftwerks and giving them a call as they are semi-local to me and seeing what can be done. Thanks in advance!
Old Aug 17, 2017 | 09:27 PM
Singh_snisen's Avatar
Same exact thing here. Already talked to KW And their solution is for u to buy their 30mm kit. Their current kit cannot handle the torque produced by the 91 blower.
Old Aug 18, 2017 | 08:08 AM
MorngWoodStewie's Avatar
Could you have a machine shop install more bolts (cut/tap/dye) etc.
Old Aug 18, 2017 | 02:38 PM
Oddly enough this is with the 30mm kit with cogged belt. This is also after the vtec solenoid bolts included with the kit broke off inside the head and I have since replaced them with Grade 12 Allen-head bolts.
Old Aug 18, 2017 | 02:40 PM
I contacted Kraftwerks and am waiting for a reply now (submitted a support ticket yesterday, called them and they said just wait till my ticket goes through). If they can’t resolve my issue with some sort of warranty replacement I will take it to a machine shop and see what can be done. This isn’t my first issue with their customer support either.
Old Jun 27, 2020 | 06:37 AM
Mykii's Avatar
I know this is a resurrection, but I'm looking to do the same thing. Mine has happened exactly as you had described... twice.. but on my Scion FR-S, but same supercharger unit. I'm hoping to step up the size of the holes and use larger screws... What was the end result of yours?
Old Jun 27, 2020 | 05:49 PM
hatalu's Avatar
Is that common known issue from KW kit? i got the 83 small blower, does that kit gives u same issue? do i need to update my belt if i stay under 410hp?
Old Jun 27, 2020 | 06:03 PM
DutchyFutch's Avatar
Common issue.
Old Jul 4, 2020 | 06:20 PM
beechx1's Avatar
I drilled out the V-Tec holes and put Time-Sert steel thread inserts in. Then got ARP bolts and installed KW's new support bracket.
Anees
Sep 9, 2018 10:46 PM
beaudin223
Feb 12, 2016 03:39 AM
Bran916
Dec 3, 2015 07:58 AM
RAIN H8R
Jul 7, 2015 07:07 PM
rhauri
Jul 1, 2013 06:09 AM
