LASKEY built engine. expected oil temps?
Old Sep 1, 2012 | 10:32 AM
GrandMasterKhan's Avatar
Default LASKEY built engine. expected oil temps?
Hey Guys, I am trying to get everything together so I can finish my turbo build but I have had some oil consumption issues with my Laskey Built engine. The inside of the engine looked like the oil had gotten extemely hot so i had it rebuilt and they claimed I had worn the piston rings flat due to a bad tune. :/ No sure how much I can believe that but I was running the OEM tune.
i have since had the engine rebuilt but am STILL having oil consumption issues. (i changed the oil every 1k miles or sooner over the past 6k miles). This time I DID have it tuned, and just as before followed the break in proceedure to the T. I ran my most recent oil change to roughly 1500 miles and the oil came out blacker than hell, with sludge and what not. I have pictures. I am currently running an oil consumtpion test to see how much oil it uses over a 1000 mile period.
I am not sure but it seems the oil temp is getting much too high just for normal driving. I am currently seeing oil temps of 220-239 just driving around back and forth to work. no vtec. just daily driving. Temps are measured from a sandwhich adaptor @ the oil filter/oem oil cooler. What is the normal expected oil temps? if I am way over what could possibly be causing such high oil temps?
My coolant temps are ranging from 180-210ish as measured from the oem temp port on my FullBlown radiator (outlet of the radiator). Highest coolant temp i have seen is 225 when it was over 110 degrees in stop and go traffic. I have bled the coolant system many times. (I work for Honda and have Honda master techs available)
engine is NOT turbo yet, i am running it NA, I currently have the intercooler installed, but have not finished the turbo built yet. I cant imagine 240 degree oil temps are normal, I can only imagine what they would be on the track n/a much less with a turbo!! I do have a mocal oil/water oil cooler but have not installed it yet.
engine specs:
2006 DBW
10.5 CP pistions
2.0 Benson Sleeved Shortblock
Pauter Rods
oil squirter delete
Asura Baffled oil pan
Full Blown radiator
2.2 cams
supertech valve train
Old Sep 1, 2012 | 12:53 PM
razzele's Avatar
I'd say that's very high, I'd only see those sort of temps on track with my SC setup.
Old Sep 1, 2012 | 01:17 PM
Spoolin's Avatar
I wonder if your oil squiter delete could be causing the pistons to get hotter and thus the oil temps rising. I'm not a fan of deleting the oil squiters, Honda put them there for a reason.
Old Sep 1, 2012 | 01:19 PM
razzele's Avatar
What is the benefit?
Old Sep 1, 2012 | 02:05 PM
miguel329's Avatar
I and my friends never had issues with benson sleeved block with piston squirt delete.. odd issue you talk to mike at laskey?
Old Sep 1, 2012 | 02:10 PM
bobbyrandolph440's Avatar
Do you have a external oil cooler
Sent from my DROID RAZR using Tapatalk 2
Old Sep 1, 2012 | 05:13 PM
i am currently using the oem oil cooler
Old Sep 1, 2012 | 05:40 PM
That's just crazy how hot its getting
Old Dec 21, 2012 | 04:14 PM
JUSTINTHECOASTIE's Avatar
Any updates GMK?
Old Dec 21, 2012 | 05:53 PM
HvRRZ's Avatar
What oil are you running?
Can you check your oil pressure?
Other things to check... thermostate and waterpump... headgasket..
gtolot
Dec 13, 2003 12:56 AM
LostWaffle
Nov 10, 2003 10:29 AM
navybeaN
Jul 15, 2003 08:04 PM
demonderrick
Jul 16, 2001 08:47 PM
