In light of a recent Blown HG for one of our
Originally Posted by dsddcd,Feb 17 2009, 02:06 PM
Be careful what you read, in fact most bolts are torque to yeild and going tighter may apply more force but the factigue restitance will go way down. I would highly recomend following the factory procedure and then retorquing after heat cycling for good measure.
Engineering 101, the greater the stresses the shorter the lift span
Scott I'm having highschool flash backs seeing them again.
(I went to a trade school with a major in materials science)
Originally Posted by tony1,Feb 17 2009, 06:31 AM
The greddy manifold and very small turbo are very restrictive and cause a lot of exhaust reversion on the S2K because there is so much overlap in the cams. This exhaust reversion kills power causes detonation. The 'safe' power level on these cars has everything to do with the turbo kit (manifold and turbo specifically).
Originally Posted by Revenge,Feb 18 2009, 04:35 AM
I'm not so sure about, I don't think this log manifold is much differnet than any other except for the smaller flang. I am making about the same power as most using other log style manifolds.
There are many variables to blown headgaskets.
Tuning/Ignition timing.
Weather (causing boost spikes) which are tuned for.
Faulty installation.
Bad gas.
There are many more where its hard to pinpoint the problem.
Bad gas.
Originally Posted by TRBOKEV,Feb 18 2009, 10:18 AM
But....
How many people with thicker head gaskets have 30, 40, 50+K miles on it with no problems?
I really really really want one, but I want reliability also.
tunedbycft
May 31, 2010 05:53 PM
Man I feel so left out
