Liquidgsr Laguna build thread
Very nice man, keep up the good work!
On a side note, you guys are slow pokes... I did my whole turbo install overnight!
I had a lot of very knowledgeable help though. I can definitely understand why it takes the average person so long to pull it off. Its definitely not easy.
Can't wait to see it done!
/>/>I had a lot of very knowledgeable help though. I can definitely understand why it takes the average person so long to pull it off. Its definitely not easy.
I haven't worked on the car much these past few weekends. I have either had no motivation or haven't felt well. I have few things to replace and still looking for the pins for the ecu. I am just going to mail Hondata and see if I can get the pins from them. They have some available from the civic si.
Still waiting on my charge pipe and need the springs for the BOV and the Wastegate. One thing I was noticed is that my clutch pedal fell to the floor and it doesn't come back up on its own after I changed the clutch out. I probably need to bleed the clutch fluid right?
Anyways here are some pictures. Its starting to look like a car again.
Yeah bleed that clutch. Hows the clearance on that strut tower bar? You dont want it making contact with that turbine housing it may cause a weld to crack on the manifold.
Remember the engine rotates when under load.
^this i was going to say your strut bar looks close man
