Liquidgsr Laguna build thread
Originally Posted by Reapur' timestamp='1353360825' post='22160582
Yeah bleed that clutch. Hows the clearance on that strut tower bar? You dont want it making contact with that turbine housing it may cause a weld to crack on the manifold.
Remember the engine rotates when under load.
Pm'ed you.
Haven't updated this in a while.
I got the PIN from Mportracer33, thank you! I wired up the MAC boost controller to the ECU. Reinstalled it. Reinstalled the seats and interior panels and made sure the gauges work. I had a problem where the headlights weren't working and figured out I just didn't plug it in when I put the dash back together, so I fixed that.
I redid the oil adapter lines and changed some of the fittings out. I also realized I need to remove the oil cooler so I did that installed the new canton racing adapter after ordering a new one.
I should have my charge pipe back this week finally and will powdercoat it and hopefully have this done by next month maybe. I also wanted to make a board for the fuel pump relays and wires, so I am going to do that this weekend. Other than that I can't think of anything else that I need to do other than put the front end back on.
Heres some pictures. I ended up scratching the hell out of the fittings. Oh well.
Again haven't updated in a bit. Got my charge pipes back. I sanded off the red and am thinking of changing the color to Anodized Purple like the AN fittings I got from FullBlown. Its pretty much done, I just need to take the turbo off again and turn the oil drain around because its hitting the wastgate port. Other than that I need to install my fuel pump terminal board I made and put the front bumper, hood, and hardtop on. Its going to Inline Pro to have the downpipe/dumptube made, and then off to MattShue to have it tuned. Almost there.
