Liquidgsr Laguna build thread
Old Feb 11, 2013 | 05:16 AM
  #231
liquidgsr's Avatar
Also realized im a dumbass and didn't think to just clock the turbo to get the oil drain to sit in a different spot to get it up properly. I will have to do that this weekend. Then I will offically done with my part.
Old Feb 11, 2013 | 05:19 AM
  #232
herecomesboost's Avatar
Originally Posted by liquidgsr
To reverse the polarity do I just I need to add something or just take the lines and swap them? Id have to see if there is enough space on the other side with the AC condensor being there.
You would just swap the lines. For what it's worth, I didn't have problems overheating with my stock rad/single slim fan.
Old Feb 11, 2013 | 05:23 AM
  #233
liquidgsr's Avatar
good to know Kyle. Thanks. I don't forsee myself having problems with the stock radiator.
Old Feb 11, 2013 | 01:22 PM
  #234
Andrew Wojteczko's Avatar
Running a puller fan as a pusher will reduce its efficiency considerably as the blade design is different from one to the other. But you can get pusher fans.
Old Feb 11, 2013 | 01:52 PM
  #235
wy2slow_z's Avatar
^lol exactly what i told you on the phone today
Old Feb 11, 2013 | 02:55 PM
  #236
liquidgsr's Avatar
Yeah yeah zack. I'm leaving it as is. Should be okay since ill normally be driving it under low boost with the switch.
Old Feb 11, 2013 | 04:18 PM
  #237
wy2slow_z's Avatar
low boost? no you wont!
Old Feb 11, 2013 | 04:33 PM
  #238
x2
Old Feb 12, 2013 | 03:58 AM
  #239
liquidgsr's Avatar
We shall see. Haha.
Old Feb 17, 2013 | 08:18 PM
  #240
liquidgsr's Avatar
update
added a high low boost switch. Low boost will be just running off of the wastegate for normal driving, while high boost will be running full boost by gear settings.
