Little_AP1_s2k Turbo build
Old Nov 6, 2009 | 07:53 PM
  #31
Kirpich's Avatar
Not to jack the thread, just trying to help a brotha:
here is how I mounted mine:
I bought a piece of aluminum from Lowe's, it's 1/4" thick, about an inch wide, and about 3ft long. Cost like $15. Maybe more, but you can find any piece of flat metal, preferably in 3/8" thickness. Then just trace an outline of your stock MAP on it, and go to work with a dremel, or a bandsaw. Or if you like blisters, with a hacksaw and a file.
Then find a 1/4" NPT thread tap, and make the tread. Then also buy a male/female 1/4" NPT 90* brass elbow. McMaster has it, http://www.mcmaster.com/#50785k43/=4e6r6t.
You can get this at a local hardware store.
Then, a little Teflon tape, and you're golden.
Old Nov 8, 2009 | 04:29 AM
  #32
Little_AP1_S2K's Avatar
Its alive waiting for a tune day running alittle lean on my base tune. so im towing it to jeff tues morning pictures to come
Old Nov 9, 2009 | 04:08 PM
  #33
TUNE TOMORROW!! :-D
Old Nov 10, 2009 | 05:34 PM
  #34
10psi
HOWEVER TURBO WENT I THINK... so i was driving some pulls temp was fine everything was fine. and i seen it went rich and lost ALOT of power from the turbo it got some psi but yea nothin really. thought maybe a charge pip poped off. Nope none everything there and it covered everything in whiteish smoke it was night so i couldnt tell..
how much a percision turbo cost to rebuild?
Old Nov 10, 2009 | 05:45 PM
  #35
Spoolin's Avatar
You have a ball bearing Precision turbo or journal bearing. If its a ball bearing, look at close to the same amount as a new turbo to fix it. If its a journal bearing turbo, a few hundred buck will fix it.
Old Nov 10, 2009 | 05:49 PM
  #36
journal bearing just sucks... jeff seen it was losing a seal he said.
Old Nov 10, 2009 | 06:23 PM
  #37
Spoolin's Avatar
I've always used journal bearing turbo's with no problems. Maybe your drain isn't draining well. That will cause it to ruin seals.
Old Nov 20, 2009 | 06:34 AM
  #38
they said lack of oil.. even tho i have more then enough flowng there lets see what happens when i get it back 420 dollars later
seoul2k
Forced Induction For Sale
Oct 18, 2011 11:31 PM
Corey Maurer
May 16, 2011 05:19 AM
mrscbw
Jun 18, 2008 05:15 AM
03silver2000
May 18, 2008 07:50 PM
