Long trip with a turbo
Old Apr 15, 2007 | 08:54 AM
  #21
Spec_Ops2087's Avatar
Originally Posted by S2000_Europe,Apr 15 2007, 05:58 AM
ok I see, but for the comments above from other members seems like a turbo is not the best mod for long trips; do not understand me wrong, I had a Turbo kit on the S before and worked without any problems and made long trips + track session on the same day with a SC and everything went perfect.
Old Apr 15, 2007 | 09:16 AM
  #22
Raven628's Avatar
When Inilne did my first turbo set up, I drove from NOVA to Pesacola straight after installation. About 1200 miles. The tune was great. At the time the EMS was not available, I had the VFAC II spliced into the stock ECU. My car ran better at that time.
The only thing I had to add when I stopped for gas was maybe a half a quart of oil the whole trip.
Then from Pensacola to Tampa and back several times with no issues.
Eventually ( 7 months later) on a 20 min trip to work the oil pump went out and spun a rod bearing doing 50 mph. I just bought the oil pressure gauge and was going to put it in that weekend.
I just installed after the rebuild.
Here is a pic of the first build.
Old Apr 15, 2007 | 09:22 AM
  #23
JDMKID35's Avatar
Banned
everything will be ok...look at all the cars that come turbo... just because you add a turbo dont mean you cant drive it... just dont run it hard the whole way down
Old Apr 15, 2007 | 10:20 AM
  #24
s2guru's Avatar
i see, well thanks alot for the inputs, i will take my precautions,
Old Apr 15, 2007 | 11:16 AM
  #25
sean2sean's Avatar
as long as you are not hitting boost on all 2500 miles... u are good.
just make sure you make frequent pitstops and pop your hood to cool down your engine bay.
if you drive hard enough even for a short trip on boost... your turbo manifold will get red hot. im guessing thats not good.
Old Apr 15, 2007 | 03:34 PM
  #26
s2guru's Avatar
well, i will be doing 85- 95 Mph, i will try to make a quick stop every 150 miles,
Old Apr 15, 2007 | 05:22 PM
  #27
I don't think there is any need to stop and check. Just stop when you need to fuel up / eat / relieve yourself. When just cruising, the turbo isn't in boost and no real stress. Plus your having massive amounts of air going through the engine compartment to cool it down.
Old Apr 15, 2007 | 05:26 PM
  #28
BulldogS2's Avatar
at 80-85 mph, isn't it already boostin? i thought the boosting for tubos usually begin at 3K rpm
Old Apr 15, 2007 | 05:41 PM
  #29
afwfjustin's Avatar
Depends on the turbo. 3k is a little early though. Most spool up around 3800 and see full boost around 4500.
Going 85 you would be boosting.
Old Apr 15, 2007 | 07:23 PM
  #30
s2guru's Avatar
so, i would have stay on the 80 mph range? that way i'm not in boost?
