Low boost Eaton setup
Some progress, secondaries mocked up, right length, but needs a couple of tweaks to the shape before welding to smooth the flow a little:
Side profile of engine/cage now, that's the old engine rear protection cage for mockup there, you can see how much longer the old setup used to be. The top bar used to be horizontal too, so you can also see how much ground clearance we've gained!
And some of the mountings and plumbing done. Yes, that alternator IS going to be a bitch to drive.
I know the air feed into the plenum and out of the charger need a bit of work but it's a case of make something easy that works at the moment and improve it later since they're just bolt-on flanges
Starting to get a bit of a tight fit - you can just the see the silencer/muffler under the charger there too - don't worry, it's not that close to the charger, it's sat vertically there and it'll be at 45* when it's done.
s2000442
Sep 29, 2011 01:46 PM
