Low compression Franken S2k motors?
Old Jan 15, 2010 | 06:58 AM
  #91
LeonGalt's Avatar
Aw, bummer. I love this project and have really been pulling for its success (as I want to follow in your footsteps).
Hope you get it sorted and back on the road soon. GL.
J
Old Jan 15, 2010 | 07:15 AM
  #92
drewmob's Avatar
Btw, can you put these pics in a public album? I'd love to be able to get a closer look @ the pics.
Old Jan 15, 2010 | 08:13 AM
  #93
Ian300D's Avatar
Hmmmmm same oil filter I had when my engine blew. Although I don't think it was the filter.
Old Jan 15, 2010 | 08:50 AM
  #94
iDomN8U's Avatar
bummer
Old Jan 15, 2010 | 01:29 PM
  #95
Spoolin's Avatar
Try looking into the Hamp filters. They are supposed to be very good and I have been using them for years on the S with no problems.
Old Jan 31, 2010 | 04:42 AM
  #96
solomonster's Avatar
so if you ran a oem oil filter and/or a baffled oil pan would you be okay? and lower boost?
Old Jan 31, 2010 | 07:12 AM
  #97
Harpoon's Avatar
What makes you think a baffled oil pan would have helped anything here?
Old Jan 31, 2010 | 08:27 AM
  #98
TRBOKEV's Avatar
Oem filter ftw!
I only run oem.
Sorry to hear about this. Get er back up and running.
Old Jan 31, 2010 | 08:54 AM
  #99
Artisan7471's Avatar
Yea a baffled oil pan would not have helped since I was going in a straignt line. also I think my right foot was really the cause for the failure . Too much boost, Also I may have had a little too much timing at 19 psi, than I should of. I am going back to an oem filter from now on.
On a side note I am rebuilding the motor right now, But I found a problem, If you are using a f22 crank in a f20 block you have to notch the base of the cylinders for rod clearance. I installed the crank last night and when I tried to turn the crank the rods were hitting the cylinder base. Now I have to pull it apart again and notch the cylinders .
Old Jan 31, 2010 | 09:16 AM
  #100
D1sclaimer's Avatar
Sorry to hear that you learned about Fram filters the hard way. I assume you were using an Extended Guard 3593A Fram filter? If so, thats a universal filter for all Hondas filters from Fram. Theres a reason why Honda gave us a different filter than other Hondas.
Good luck to you with your project.
