Lysholm in an S2000?
Old Nov 21, 2005 | 09:07 PM
530s2k's Avatar
Default Lysholm in an S2000?
So I've got a Lysholm / Autorotor that's designed to go on VW Corrado G60 (1.8 - 8v) It's also been put on a 2.0 8v with some success, and a few 2.0 16v's...
1st question... Understand I'd have to source a pulley and mounting bracket that works... Is it even feasible though?
2nd question.. As I understand it the S2000 derives fuel from the MAP sensor... Does the MAP sensor even handle anything above atmospheric?
3rd question(s).. What else would I need? Injectors? How do the tuners handle fueling- custom ECU?
Just throwing around ideas, sorry to invade the forum with unpure thoughts.
Old Nov 26, 2005 | 05:26 AM
Slows2k's Avatar
Check out http://brpforum.infopop.cc/groupee/forums/...2871#4721092871
For a Eaton SC being developed. Packaging will be pretty similar.
The Stock map sensor can read to approx. 10psi, but the stock PCM cannot see any boost. A map signal clamp is used on both vortech and compech SC's to hide boost from the stock PCM.
You could try a FMU setup, an e-manage piggyback with larger injectors, or a standalone EMS.
Old Nov 26, 2005 | 08:06 AM
Wildncrazy's Avatar
Don't know the rotation of the charger, but could you turn it around facing the engine and mount it on the front crossmember? I've always thought that would be a good use of wasted space.
seansniper
Oct 3, 2012 11:56 PM
cariza
Jan 14, 2012 08:48 AM
Rdragon
Mar 1, 2011 11:49 PM
icemans2k02
Sep 20, 2006 07:00 AM
MB
Sep 30, 2005 11:15 AM
