MADjdm's Turbo Build
Old Jun 15, 2009 | 09:10 AM
  #31
MADjdm's Avatar
Originally Posted by Ap2spoonf20c,Jun 15 2009, 08:59 AM
Nice set up I pretty much have the same exact P-fab set up,except I have a stage 3 intercooler.Since your deleting the air pump are you going to cap that vaccum booster behid the intake manifold that runs to the airpump?And what do you do with intake air temperature sensor that came off the intake box.I'm also working on my mine at the moment and could use some advice.Thanks in advance.
I plan to cap off the hole with Inline Pro's block off plate. It can purchased through them for $29.00
Old Jun 15, 2009 | 09:24 AM
  #32
JoeyBalls's Avatar
did you get an Oil restrictor for this turbo?
I am keeping the Greddy Intercooler and piping that goes from Intercooler to T/B, so I guess I wont have the air pump issue. Hopefully the METH will help with the smaller greddy Intercooler.
Old Jun 15, 2009 | 09:29 AM
  #33
MADjdm's Avatar
Yep. I am using Full-Race's oil feed line kit (minus the stainless line due to length) that utilizes the oem pressure sensor and added an oil restrictor fitting for the turbo oil inlet.
The fittings from FR require a -3an stainless feed, which I will get made after I take the measurements once everythings mocked up.
Old Jun 15, 2009 | 09:37 AM
  #34
JoeyBalls's Avatar
got ya thanks, I know PFAB sells the oil lines and cooling lines for like 180, I wonder if it is "Oil restrictor" friendly, I dont know how those things work?
Old Jun 15, 2009 | 09:41 AM
  #35
EngineerX's Avatar
Nice!
Yeah, good call on Swain Tech. Their stuff is great and it will last, never had it flake in any of the White Lightning coatings I've used from them, unlike Jethot and HPC Extreme, both have flaked on me.
The only thing I don't like is that Swain Tech is slow at coating and sending your stuff back. Always takes about one month and being on the West coast doesn't help. Oh, yeah, I don't particularly like the whitish color either.... so I always use VHT high temp flat black paint.
Can't wait to see your final results. Good stuff!
Old Jun 15, 2009 | 09:42 AM
  #36
AndyFloyd's Avatar
I have the stage 2 IC in mine. Get rid of all the airpump crap. you dont need any of it with the EMS. pics, i wanna see pics
Old Jun 15, 2009 | 09:44 AM
  #37
MADjdm's Avatar
I was going to use PFABs, but it doesn't use stainless lines for the coolant and the fittings are made out of aluminum.
I prefer to use stainless fittings for everything as I've heard horror stories about the aluminum ones comming loose. (Andy Floyd for example)
Additionaly, PFABs lines source coolant by the throttle body, while I plan to weld -6an bungs to the oem oil cooler as 300sx did in his build.
Oil feed will be -3an
Oil return -10an
Water feed/return -6an
Old Jun 15, 2009 | 02:05 PM
  #38
AndyFloyd's Avatar
Oil return -10an
ah yes i spliced the oil cooler lines and used those with no trouble whatsoever.
Old Jun 15, 2009 | 06:54 PM
  #39
JoeyBalls's Avatar
might be a dumb question, but where are you tapping for the OIL FEED, OIL RETURN and WATER FEED/RETURN
Thanks for ur help I will be pretty much doing what you are doing, so I will use you as my guide
Old Jun 15, 2009 | 09:13 PM
  #40
AndyFloyd's Avatar
oil feed - stainless T 1/8"npt ( i think ) one for stock oil sending unit, one for oil feed line. -4an line w/ stainless restrictor.
oil return- -10an stainless braid hose, tapped top of oil pan.
coolant- tapped stock oil cooler lines, ran t fitting for in/out. stainless braid hose unsure of size...-6an maybe.
